Results 1 to 8 of 8
Thread: My Pete 362 is making me blue
    CookieMonster is offline Rookie
    Jan 2010
    2
    Default My Pete 362 is making me blue
    So I go out to start up my '94 Pete cabover and as soon as I turn the key to the start position-NOTHING! No low air warning buzzer, no dash lights, no accessories, nothing. It's like the cab has no electrical power at all. The interior light came on for a few seconds and then faded out never to come back on again. I thought it was the batteries so I tried to jump it to no avail. I pulled all four batteries and tested them and they all read fully charged. The battery posts and connections are all clean. So this leads me to believe that a connection is loose or maybe a main fuse is bad. Am I on the right track? This truck has started religiously no matter how cold for as long as I've owned it (about a year and a half) and has been bullet proof reliable until now. Anyone have any ideas? Thanks.
  2. #2
    bikerboy is offline Board Regular
    Aug 2005
    Southern Ontario Canada
    280
    check your ground from the batteries to the frame
  3. #3
    GMAN is offline Administrator Board Icon
    Feb 2005
    Tennessee
    15,247
    Your ground would be the most suspect, especially if your batteries are charged. I would check all cables starting at the batteries.
  4. #4
    Roadhog is offline Board Icon
    Sep 2005
    I gotta breeze up me Kilt
    7,258
    Yep, what they said.
    This is the no.1 place to look.
    Lots of vibration loosens even breaks this connection.
  5. #5
    Jackrabbit379 is offline Board Icon
    Oct 2005
    Wichita Falls,Tx
    7,100
    Yeah, I would check the ground.
    If not that, it might be the mother board. The grandmother of them all that runs the whole kit kaboodle.
  6. #6
    Jan 2010
    2
    Okay I'll check the ground. Thanks for all your suggestions.
  7. #7
    Sep 2005
    7,258
    From your discription, (no accessories) just seems most likely ground strap to the frame. Next suspect for me would be the starter switch, then main fuse.
    Is there a battery cutoff switch?
  8. #8
    Maniac's Avatar
    Maniac is offline Senior Board Member
    Sep 2004
    Northeast
    963
    Your battery cables may be bad, especially if they are the original ones, some times they corrode from the inside out, ask me how I know :-)
  9. This ad will disappear if you login
Tags for this Thread
