11-28-2009, 09:40 PM
BANNED
Antefreeze ,,leak''..pics included.
Pictures will explain it more easily but i have antifreeze leaking right out of some kind of a breather hose underneath my cab, passenger side right where all the AC lines go in....its leaking more in colder weather and it has been doing it for a while with no issues. Am not noticing that am loosing any coolant at all...its a DD60, 400K miles, 475hp.
What is this hose called and what is its purpose?
11-28-2009, 09:42 PM
BANNED
Thats the hose am talking about right next to the AC lines..
11-28-2009, 09:43 PM
BANNED
The aftermath.....
11-28-2009, 09:59 PM
sure looks like coolant leak in the core and it is coming out the condesation tube.
11-28-2009, 10:05 PM
BANNED
Its doing it while am parked BTW.
11-28-2009, 10:44 PM
Do you have a heater core in there with the a/c condenser? It could be the core or a hose leaking when it's cold. I would check the hose clamps & core.
You need to wash your truck too.
The Big Engines
In the Night-
The Diesel on the Pass
-Jack Kerouac, "Mexico City Blues"
11-28-2009, 10:57 PM
BANNED
Man i don't even know how to check for that, ill see about it though.....
Hey, thanx..
No use..
Places where we load at are about foot deep in all kinds of *****, from limestone to gypsum and clay. If i wash it today, itll be back to looking crappy tomorow.
11-29-2009, 01:29 AM
Yes, the heater core is in there along with the A/C evaporator.
Those 2 rubber 90 deg. lines with the spring type clamps on them are the coolant lines to the heater core.
There is a leak in the heater core, or in the lines inside the HVAC unit and the leaked coolant is draining out the drain tube that is there to allow A/C condensation to drain out of the HVAC unit when using the A/C.
You'll have to pull the lid off the HVAC unit inside the cab and have a look.
11-29-2009, 03:09 AM
BANNED
There is a leak in the heater core, or in the lines inside the HVAC unit and the leaked coolant is draining out the drain tube that is there to allow A/C condensation to drain out of the HVAC unit when using the A/C..
Thank you my friend...
Is that the black box type thing underneath my bed, on a passenger side?
11-29-2009, 12:13 PM
I always work on day cab Internationals, and on those the HVAC unit is under the passenger seat, however, by looking at your pics, I would say yes, the HVAC unit is in your sleeper on the passenger side, directly above where those hoses go thru the floor.
