+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 32
Thread: air bags
    heavyhaulerss's Avatar
    Jan 2007
    north alabama
    1,186
    Default air bags
    is there a good way to keep my trailer air bags from stretching when unloading? I haul heavy single steel coils & I just noticed that I have 3 air bags leaking right at the bottom seam. I noticed this cause of all the rain water bubbling. the 3 that were leaking all all new.( installed within the last 6 months -3 years. the one original bag has no leaks yet. before buying all new bags. AGAIN... what can I do to keep the new ones from stretching until they rip also?
  2. #2
    chris1 is offline Senior Board Member chris1 is on the right path.  You could probably safely loan them a quarter.
    Jan 2009
    541
    Chains between the frame and axle. You can also hook them shorter to use as a "lift" axle when MT.
  3. #3
    trucktool is offline Rookie trucktool is an unknown poster at this point.  Don't let him/her around power tools just yet.
    May 2009
    17
    Quote Originally Posted by heavyhaulerss View Post
    Dump your suspension before unloading.
    Proper shock absorbers should NOT allow the bags to over-extend.
  4. #4
    Kranky's Avatar
    Jun 2006
    Wisconsin
    1,108
    Are the new bags the proper ones for that application?
    It seems strange that the ancient "original" bag is still OK, but the 3 replacements are leaking.
    I agree that you should dump the air suspension before unloading.
  5. #5
    Jan 2007
    north alabama
    1,186
    yes the bags are the correct replacement. I took the old one off & truckpro ran the numbers & gave me the original hendrickson bag. I relate the one not leaking to the same ole. (they dont make em like they used to). I have seen recently a lot of flat bedders with chains that appeared to be hooked in such a way. i dump my suspension valve. it is hooked up to my front axle. it does no good for the back. it would take too long to dump most of the air. I know I have wore out shocks. I guess i could chain the alxle to the frame, since it wont cost me anything & get new shocks on trailer & see if that is the problem. the chains I have seen recently are on newer trailer though & I would not think the shocks would be wore on newer equip. I also have noticed lately that my bags strech so much , that I wonder what has kept them in tact this long. maybe my shocks have worn completely out & that explains more stretching now than in the past. on chaining...I dont want to weld anything. would looping a chain around the axle to directly above around frame & leave limited slack work ?
  6. #6
    Bandit102's Avatar
    Bandit102 is offline Board Regular Bandit102 is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Nov 2006
    Denver, CO
    338
    My Wilson flat has nylon straps around the shocks to prevent over extension.
  7. #7
    Kranky's Avatar
    Jun 2006
    Wisconsin
    1,108
    Check your ride height adjustment, sounds like it may be set too high.
  8. #8
    Jan 2009
    541
    The shocks should "top out" before the airbags over-extend. If they don't they are the wrong shocks. Chains/straps prevent the shock from breaking when the axle suddenly drops down.
  9. #9
    Jan 2007
    north alabama
    1,186
    I set the height myself shen I replaced the leveling valve a while back. comapared to all others I have noticed, mine are not too high. mine are lower than most all I see. I have just put 1 chain on each axle to the frame, with just enough slack to the maximun height I want allowed. will be gettting new shocks & put them on this week. the shocks are original equip. thanks for all the advice.
  10. #10
    Jan 2007
    north alabama
    1,186
    so far the chains I installed are working very well containing the air bags to an acceptable level. thanks 4 all the advice
  11. #11
    GMAN is offline Administrator Board Icon GMAN is a distinguished poster and probably helps little old ladies across the street. GMAN is a distinguished poster and probably helps little old ladies across the street. GMAN is a distinguished poster and probably helps little old ladies across the street. GMAN is a distinguished poster and probably helps little old ladies across the street.
    Feb 2005
    Tennessee
    15,106
    I was just wondering if you were able to get your shocks changed out and if that solved your problem, heavyhaulerss?
  12. #12
    Jan 2007
    north alabama
    1,186
    No I have not had a chance to get the shocks on. it has rained for almost 2 weeks straight. & now that this week has been dry, I have more loads than I can handle. I am going to try & get it in my shop this wknd. I put 1 chain around each axle to the frame above it, with enough slack for the air ride, but will prevent the bags from stretching over their limit. the chains seem to work well so far. as easy as the shocks appear to replace, if I do it during the week I would have to give up a load & I dont want to lose any $$. been doing a lot of 120-150 mile runs & the time it would take me to install shocks, I would have to give up a load. if freight stays like it has for me this mon & tues, I'll just have to run 18 loads a week for 1 year to make up for what I have not earned in the past 14 months. last week I had 3 loads all week. so far this week I have 5 loads done & its only tues night. sooo maybe fri or sat I will do some work on equip.
  13. #13
    Les2 is offline Rookie Les2 is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Sep 2008
    31
    Put two quick release valves on the trailer, one for each axle.
    The only thing your doing with the chains is stopping the trailer from raising up real high giving you the impression your bags aren't getting over inflated, when in fact they still are!
  14. #14
    Kranky's Avatar
    Jun 2006
    Wisconsin
    1,108
    Quote Originally Posted by Les2 View Post
    If the chains he installed are preventing the air bags from physically extending past their maximum rated height, then it would be physically impossible for the air bags to "Hyper extend".
    As for being over inflated, the term "over inflated" means that the pressure is in excess of the air bag's rated P.S.I. capacity.
  15. #15
    Sep 2008
    31
    Quote Originally Posted by Kranky View Post
    Guess you didn't get the point. Oh well not my bags or crossmembers getting beat up.
    Although I do have one question...does anyone have an air gauge on their trailer? If so,, watch it when they pull a big coil off and let me know what the air pressure goes up to. I'm just curious as to if it goes up alot?
  16. #16
    Kranky's Avatar
    Jun 2006
    Wisconsin
    1,108
    When you suddenly take weight off an air suspension the air pressure in the air bags will drop, not rise, because the bags will extend further as the weight is removed, increasing the inside volume of the bags, and no more air is being introduced into the bags. At this point the ride height control valve has sensed an increase past the normal ride height and is actually exhausting air from the bags to bring the ride height back to normal.
    But if the air suspension is "dumped" before unloading, hyper extension of air bags is a non issue.
  17. #17
    Sep 2008
    31
    Exactly! The airbag is rated to handle the air pressure thats in it even if its extended all the way. Now none of us like this to happen but the bag should still handle it.
    Where I see people make mistakes is putting the bags on crooked or twisted and this can cause problems and a shortened life of the bag.
    Like you said a dump valve is the best option. Or if you have a good leveling valve (not the cheap crappy plastic slow ones)and two quick release valves with 1/2" air lines, you can go without the dump valve and the airbags will last a long time.
  18. #18
    Jan 2007
    north alabama
    1,186
    I have used the air dump. it does nothing for the axle that has no air dump. the axle with no air dump still raises the trailer & then lifts both axles up, stretching the all the air bags.
  19. #19
    Jan 2007
    north alabama
    1,186
    I do have new, but cheap plastic leveling valve on trailer. it is what truckpro sold. if I can get a better one, that I knew for sure would work better I would. maybe for some reason the air is not being dumped quick enough. though I know this is not a prob that I just discovered, as I notice more & more flats, with the chains attatched.
  20. #20
    Kranky's Avatar
    Jun 2006
    Wisconsin
    1,108
    Then you should re configure your plumbing so you can dump the air from both axles while unloading.
    We have some dump trailers with air ride where I work, and they are set up to dump the bags whenever the air operated tailgate is in the "open" position. Since the tailgate is opened when unloading, the air suspension is "automatically" dumped. (Unless the driver f's up and forgets to open the tailgate, but that's a whole 'nother set of problems if that happens.)
+ Reply to Thread
