+ Reply to Thread
Results 1 to 8 of 8
Thread: Help; Reviving Dead Outlets??
    dualqwad's Avatar
    dualqwad is offline Member dualqwad is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Nov 2002
    Warehouseville
    123
    Question Help; Reviving Dead Outlets??
    I want to be able to use my cooler and my television on board this POS Columbia class Freightliner but none of the 12VDC power outlets in the rear are hot.
    I have already checked for blown fuses marked "Fridge" or "TV" at the fusebox underneath the dashboard cover.
    I found nothing....
    What or where else should I be looking for them?
    Thanx in advance for any help from any one.
    You could learn alot from a dummy.
    BUCKLE YOUR SEATBELT
  2. #2
    Sabine's Avatar
    Sabine is offline Board Regular Sabine is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Feb 2006
    Fredericktown, MO
    300
    you have another fuse panel, to the left of the drivers seat. That's where that fuse for your bunks 12V outlet is. Don't ask me which one, but I just read about it somewhere, and I believe they said it was the 15W one.
    Hope this helps.
    For Anthony, who was taken from our lives much too young. I love you honey, and I will always miss you.
    ~21 December 1973 - 29 September 2006~
  3. #3
    Windwalker is offline Board Icon Windwalker is a distinguished poster and probably helps little old ladies across the street. Windwalker is a distinguished poster and probably helps little old ladies across the street. Windwalker is a distinguished poster and probably helps little old ladies across the street. Windwalker is a distinguished poster and probably helps little old ladies across the street.
    Oct 2005
    Been there and gone...
    6,187
    Quote Originally Posted by Sabine View Post
    Hope this helps.
    Yeah, and you just about have to remove the driver's seat to get to it.
    Not really, but you do have to position the seat out of the way, then get the curtains out of the way too. I have one that is not working in the back corner of the bunk. I've even had the panel off and checked that out too. The fuse should be in the panel next to the driver's seat, but I can plug a fuse into every one of them and that outlet does nothing at all. Learning to live without it.
    Destroy the cities...
    and they will rebuild them.
    Destroy the farms...
    The bill has come due.
  4. #4
    dualqwad's Avatar
    Nov 2002
    Warehouseville
    123
    Cool Been There Too...
    Thanks folks!
    I checked inside the wall panel next to the seat (both of 'em) and found no additional fuse panel in either side.
    I did find a pair of wires (on the driver's side) with inline fuse holders in them but neither one looked blown.
    I can live without the bunk outlet but would really like to get power to the cooler 'closet' and the television 'cove'.
  5. #5
    Sabine's Avatar
    Feb 2006
    Fredericktown, MO
    300
    When I had the same problem as you, my dealer (the one locally here), just pulled out the old fuse, put the new one in and let it go.
    You got a place that you go to often enough that they know you? Ask them about it. My truck was a 2007 that had that problem, but I am sure that this is not the only year where the second panel was in that spot.
    I don't think I could let that go, I need the extra out lets.
  6. #6
    Oct 2005
    6,187
    There's a little door built into the wall behind the driver's door. You have to use a flatblade screwdriver to unlock it. Move the seat all the way forward and (i believe) down. Tilt the backrest all the way forward, move the curtains out of the way, and look at it from behind the seat. There are a couple of fuses in there.
  7. #7
    Fredog is offline Senior Board Member Fredog is a trusted source of information and would probably pick up your dry cleaning. Fredog is a trusted source of information and would probably pick up your dry cleaning.
    Apr 2005
    North Georgia
    3,663
    you could get one of those adapters that make one outlet into however many, and get some wire, make your adapter as long as you need to go from the front to the back, maybe run it under the mats or behind some trim, that would be quick and cheap
  8. #8
    avguy's Avatar
    avguy is offline Rookie avguy is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Feb 2009
    Owego, NY
    49
    Quote Originally Posted by Fredog View Post
    Just be sure to use the largest practical wire and do your electrical math so you don't end up starting a fire.
  9. This ad will disappear if you login
+ Reply to Thread
