Getting new drums and shoes put on the front rear axle of the truck. I only got fifty thousand miles out of them. The rearest axle, that was put on at the same time as the front will probably go 100,000 miles, still plenty of pad left.
Now, my mechanic called the parts shop to order the new shoes and asked them about these shoes and should he switch to a different shoe. He was told that operations similar to mine some shoes are being changed at 28000 miles.![]()
I just came from the shop and my mechanic found that my cans were different sizes, we also replaced the slack adjusters because they weren't functioning properly. I hope this solves my problem. The brake shoes were worn much differently on the front rear axle as well. One set was down to rivets and the other side probably at 1/3 of the original size.
What kind of miles do you guys get out of a set of shoes and do your front and rear axles wear evenly or does the front (rear) axle tend to wear faster?
I saw it printed on the side of the shoes yesterday, but like I said the rear shoes look good and it's the same shoe as the new one and the old ones that we just pulled off that were worn out so..........
I dunno??
