+ Reply to Thread
Results 1 to 5 of 5
Thread: Marker lights
    Ronm is offline Rookie Ronm is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Dec 2007
    Gates, North Carolina
    33
    Default Marker lights
    My marker lights are not working on my FL70. Amber lights mounted on the fender works. However, none of the others do. Checked and swapped out all the applicable breakers and fuses. Still no lights. Any ideas for how to trouble shoot further?
    I deserve respect for the things I DO NOT DO.
  2. #2
    Larry227 is offline Member Larry227 is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Sep 2008
    British Columbia
    50
    Could be the switch. If not you might have to start at one that's not working and trace the wiring back until you find the problem. Chances are it will be at the firewall or along the frame rail at a weatherpack plug.
  3. #3
    Dec 2007
    33
    None of them work.
  4. #4
    chris1 is offline Senior Board Member chris1 is on the right path.  You could probably safely loan them a quarter.
    Jan 2009
    541
    Check the wireing by the hood hinges. Pretty common to rub through/break there.
  5. #5
    Dec 2007
    33
    Thumbs up
    Got it fixed. Was a short behind the fuse panel. Thanks for the replies.
+ Reply to Thread
