+ Reply to Thread
Results 1 to 19 of 19
Thread: Does anyone where you can get a boost pressure gauge kit?
    tracer's Avatar
    tracer is offline Senior Board Member tracer is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Mar 2007
    Cambridge, Ontario, Canada
    1,316
    Default Does anyone where you can get a boost pressure gauge kit?
    I wanted our shop to install the boost gauge on my truck but they told me "it'd be too expensive" and that I'd be better off buying a "kit". Called an International dealer and the guy never got back to me. Are there any sources of such gauges online somewhere? I tried searching via google but didn't find anything for heavy trucks
  2. #2
    Fredog is offline Senior Board Member Fredog is a trusted source of information and would probably pick up your dry cleaning. Fredog is a trusted source of information and would probably pick up your dry cleaning.
    Apr 2005
    North Georgia
    3,663
    Quote Originally Posted by tracer View Post
    try truck pro
    http://www.truckpro.com/docs/parts_s...tr_index2.html
  3. #3
    FunkRider is offline Rookie FunkRider is an unknown poster at this point.  Don't let him/her around power tools just yet.
    May 2009
    Hamilton, Ontario
    34
    What kind of boost levels do you need to monitor? Pressure is pressure. Autometer makes boost gauges up to 100psi etc for cars. They also make mechanical and electric gauges in both analog and digital displays in all kinds of styles and colours.
    Electric gauges use a pressure sensor you install on the engine to take a reference signal and the gauge you install in the dash displays the boost based on the sensors output voltage.
    Mechanical gauges use air pressure to move the needle in the gauge and have a boost pressurized line running from the engine to the dash.
    I like mechanical boost gauges in my turbo gasoline cars but in a diesel truck that spends a lot of time in boost I would use an electric boost gauge as mechanical gauges can go out of adjustment with sustained high levels of boost.
    here are some of the many gauges Autometer makes in 0-60 psi.
    Auto Meter
    Auto Meter
    Auto Meter
    Auto Meter
    Auto Meter
    Auto Meter
    Auto Meter
    Auto Meter
    Auto Meter
    Auto Meter
    Auto Meter
    Auto Meter
    Auto Meter
    Some have different lighting options etc find the style you want then buy from ebay or summit racing using the autometer part number.
    EDIT, your from guelph so buying from Summit or ebay might leave you with border charges ordering from the US. Try a local retailer in Guelph like Performance Speed & Sport etc
  4. #4
    Maniac's Avatar
    Maniac is offline Senior Board Member Maniac is on the right path.  You could probably safely loan them a quarter.
    Sep 2004
    Northeast
    956
    My KW has a mechanical boost gauge from the factory, it goes to 80 PSI, if you have twin turbos you will need a higher boost gauge than I have, since I have a single turbo. I uses a 1/4" plastic air brake line rated at 200 PSI to the intakes side.
    In a hard pull I can pin the gauge, but it usually is around 60 PSI
  5. #5
    tracer's Avatar
    Mar 2007
    1,316
    Quote Originally Posted by Maniac View Post
    My KW has a mechanical boost gauge from the factory, it goes to 80 PSI, if you have twin turbos you will need a higher boost gauge than I have, since I have a single turbo. I uses a 1/4" plastic air brake line rated at 200 PSI to the intakes side. In a hard pull I can pin the gauge, but it usually is around 60 PSI
    Thanks, guys for the comments. I have twin turbos, so I probably need a gauge that can show more than 60 psi.
  6. #6
    specialkay is offline Member specialkay is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Dec 2008
    Southern Ontario
    90
    A boost gauge is just an air gauge so any air gauge should work. You know, like your brake application gauge. You should be able to get one for free or near to it at any wreckers or somewhere they're are parting out an old truck.
  7. #7
    May 2009
    Hamilton, Ontario
    34
    And like I said autometer has boost gauges that read up to 100 psi.
  8. #8
    tracer's Avatar
    Mar 2007
    1,316
    Quote Originally Posted by FunkRider View Post
    ... your from guelph so buying from Summit or ebay might leave you with border charges ordering from the US. Try a local retailer in Guelph like Performance Speed & Sport etc
    thanks for the tip. i ordered a digital 60 psi gauge from autometer. thought my dispatch would send me towards detroit, mi with the next load and ordered the gauge from a detroit dealer. as my luck would have it, i got sent to ... north carolina. ups courier brought it in ... our night shift mechanic installed the gauge on my truck on the same day. took me a while to figure out it was even working i did a couple of circles in the yard at 20 MPH and the reading was "0". complained to the mechanic and he suggested i take the truck on the highway. did that and after 35 mph the gauge finally came to life! it works and looks very good.
  9. #9
    solo379's Avatar
    solo379 is offline Senior Board Member solo379 is on the right path.  You could probably safely loan them a quarter.
    Feb 2004
    3,611
    it works
    So, what's your pressure at the full blast?
  10. #10
    Aug 2005
    jackassville (winnipeg, mb)
    3,181
    Local place I know has mechanical gauges pretty cheap and accurate. You could hook it up for $40 probably. Not an actual dash gauge though. More like something off of an air compressor.
  11. #11
    trucktool is offline Rookie trucktool is an unknown poster at this point.  Don't let him/her around power tools just yet.
    May 2009
    17
    so... whos boost gage is going over 80psi??
  12. #12
    May 2009
    Hamilton, Ontario
    34
    edit oops
  13. #13
    tracer's Avatar
    Mar 2007
    1,316
    Quote Originally Posted by solo379 View Post
    I'm from Ontario, Canada and we have a law that says all Class 8 trucks must be governed at ... 65 MPH. But I am pulling a dry van with 26,000 lbs in the box from Guelph, ON to North Carolina right now. I went over those steep long hills on i-76 east of Pittsburgh, PA without shifting while keeping an eye on the boost gauge. I had the cruise control set at 1,400 RPM (61 MPH with my 3:73 rears and LP 295 tires). The maximum reading I got was 42, which I understand isn't half bad.
  14. #14
    kelgar50's Avatar
    kelgar50 is offline Rookie kelgar50 is an unknown poster at this point.  Don't let him/her around power tools just yet.
    May 2008
    38
    I have Autometer gauges as well the C2 100 psi boost gauge less than $100 and then got another boost that is also a vac. gauge that is setup for the air cleaners to monitor vac pull on them and there pyro kit which is well worth the $199.
    You get the wiring and probe kit for it and it's a 2 1/16" gauge so it fits factory gauge holes the pyro goes to 2000*f.If I hit that I think we have a problem.
    I plan on picking up a fuel pressure gauge next.
  15. #15
    May 2009
    Hamilton, Ontario
    34
    Quote Originally Posted by kelgar50 View Post
    You have a check valve on the vacuum gauge so it doesn't see boost right?
  16. #16
    kelgar50's Avatar
    May 2008
    38
    It does not see any boost I took out the filter minder that came with the truck that is on the alum. air tubes coming in from the air cleaners after the 2 meet and installed it there.It will only pull vac. when there is a restriction in the filters.
    I never liked those filter minders because half the time they don't work.
  17. #17
    May 2009
    Hamilton, Ontario
    34
    Ah! Yeah didn't think about that. I'm still used to gas turbocharged engines.
  18. #18
    Oct 2006
    Nb
    794
    gas turbocharged engines still do not have boost on the inlet side of the turbo; his vacuum gauge is for air inlet restriction.
  19. #19
    May 2009
    Hamilton, Ontario
    34
    Quote Originally Posted by bob h View Post
    I'm well aware of that... You install a vacuum gauge on the vacuum side of the throttle plate on a gas engine which will also see boost if boost is present.
  20. This ad will disappear if you login
+ Reply to Thread
