+ Reply to Thread
Results 1 to 18 of 18
Thread: when to replace turbo ?
    heavyhaulerss's Avatar
    Jan 2007
    north alabama
    1,186
    Default when to replace turbo ?
    Do turbo's need replacing at a certain time or mileage? I have not had any problem out of mine. however my engine has over 1.3 mil on it with original turbo. the last thing I want is for a major component to go out while on the road. I'm the preventative maintenance kind of guy. so should I replace or just keep what I got? also.. I remember turbo's on the 500 detroits going out like crazy a while back. I believe it was the turbo mfr & not detroit diesel. what was the failing brand & the good one?
  2. #2
    Windwalker is offline Board Icon Windwalker is a distinguished poster and probably helps little old ladies across the street. Windwalker is a distinguished poster and probably helps little old ladies across the street. Windwalker is a distinguished poster and probably helps little old ladies across the street. Windwalker is a distinguished poster and probably helps little old ladies across the street.
    Oct 2005
    Been there and gone...
    6,187
    I'd pull the pipes off the turbo so that I could grab it and see if it has any play. If there is any radial movement in the shaft, or if there is evidence of oil leaking through the seals, I would replace it. If it's solid and spins free, I would not be too concerned. With the mileage you mentioned, I would expect it to be a little loose. I guess I'd consider it "paid for" at this point.
    When I blew a turbo, last year, it was a $27000 repair, including towing. Look for evidence of oil in the pipe to the intercooler. On the exhaust side, it should get burned as soon as it leaks out.
    Destroy the cities...
    and they will rebuild them.
    Destroy the farms...
    The bill has come due.
  3. #3
    Rev.Vassago is offline Guest Board Icon Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name.
    Apr 2006
    The other side of the coin
    9,411
    Quote Originally Posted by Windwalker View Post
    If you paid $27,000, you definitely overpaid.
  4. #4
    FunkRider is offline Rookie FunkRider is an unknown poster at this point.  Don't let him/her around power tools just yet.
    May 2009
    Hamilton, Ontario
    34
    27,000? Even if the impeller exploded the chunks should not travel past the intercooler.
  5. #5
    Kranky's Avatar
    Jun 2006
    Wisconsin
    1,108
    $27,000?
    For a new turbo & installation?
    You could buy 2 complete factory rebuilt engines for $27,000.00.
  6. #6
    Oct 2005
    6,187
    My error... It was $2700. Didn't look at how many zeros I put in there
    Sorry.
  7. #7
    Oct 2006
    Nb
    794
    Quote Originally Posted by heavyhaulerss View Post
    Turbocharger wear IS measureable. The turbo prop shaft is checked for axial and radial play. If you grab each end of the shaft, push down on one end and pull up on the other. If you can make the turbine or compressor wheel touch the housing, it's worn out. This movement, as well as the axial movement, should be measured with a dial indicator. Also, the turbo wheels wear from air abrasion and you could very well notice a big difference in performance/boost pressure if you replace a worn turbo. Then, there's seals, the turbo is fed lube oil at engine oil pressure, so they can pump oil through to the intake, and cause an internal meltdown.
  8. #8
    tracer's Avatar
    tracer is offline Senior Board Member tracer is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Mar 2007
    Cambridge, Ontario, Canada
    1,316
    I still have the original CAT manual in my 2004 truck. I looked at the maintenance schedule and CAT recommends checking the TURBO around 300,000 miles (I think). So, I took the truck to a CAT dealer and had inspected the turbo inside and out and gave me a clean bill of health. I'd go by what the manual recommends ...
  9. #9
    Aug 2005
    jackassville (winnipeg, mb)
    3,181
    You change it just before it blows.
  10. #10
    May 2009
    Hamilton, Ontario
    34
    That 300,000 mile number comes from doing the bare minimum on maintenance. Good quality oil changes and air filter changes on time and proper care with a very cold/hot turbo will net much longer life from a turbo.
    Turbo shaft play doesn't usually go from zero to out of service spec in 10,000 miles either. Check on it on a regular basis and you'll spot a problem before it happens.
  11. #11
    Jan 2007
    north alabama
    1,186
    Thanks for the info.
  12. #12
    Maniac's Avatar
    Maniac is offline Senior Board Member Maniac is on the right path.  You could probably safely loan them a quarter.
    Sep 2004
    Northeast
    956
    Quote Originally Posted by allan5oh View Post
    I tried that but missed it by a minute or so.............it was at 830,000, dealer said it was WAY past time.
  13. #13
    Bandit102's Avatar
    Bandit102 is offline Board Regular Bandit102 is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Nov 2006
    Denver, CO
    338
    I just replaced the one on my Cummins this weekend. Put in new injectors and 640 miles later lost the turbo. Its an easy fix to do yourself. Got the reman turbo from Freightliner for $622. Seems like the shops always over price them...big time. I gotta completely echo what Bob H said. I didn't bother checking mine when I overhauled the engine at 964,000 and put it in this truck. I've got about 79,500 on the overhaul now. I should have used the old dial indicator on the turbo.
  14. #14
    May 2009
    Hamilton, Ontario
    34
    Dial indicator isn't required for the quick checks you should be periodically doing. Try to wiggle it with your fingers and give it a spin. If it has a questionable amount of movement then bust out the dial indicator.
  15. #15
    Jan 2007
    north alabama
    1,186
    sooo.. new or rebuilt ? and replacement can be done without any special tools or equip ?
  16. #16
    Jan 2007
    north alabama
    1,186
    what about brand ? holset, garrett , borg warner, Iinternet diesel new, no core needed for $650.00. the diesel store rebuilt garrett for $486.00.
  17. #17
    moe
    moe is offline Member moe is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Aug 2008
    Lyman,sc
    88
    Default brand
    I put a brand new garrett on my Cummins and it did a great job. I did not need an exchange and it was half the price of the Holset. As far as installation the most important thing to remember is to prime the oil inlet so it's well lubed when starting. I put oil in both the supply and return sides (of bearing) and rotate rotor to make sure the oil gets in there good. Also when you first start engine let it idle several minutes before reving up or driving. It's a good idea to let the engine idle down for a few minutes after parking to allow the turbo to cool down(after running hard) that will help increase turbo life
  18. #18
    Fredog is offline Senior Board Member Fredog is a trusted source of information and would probably pick up your dry cleaning. Fredog is a trusted source of information and would probably pick up your dry cleaning.
    Apr 2005
    North Georgia
    3,665
    you should always carry the rubber hose and wire with you, if it gets a hole in it, it can cause serious problems and is very expensive to have fixed on the road,you can change it yourself in few minutes provided you have one with you
  19. This ad will disappear if you login
+ Reply to Thread
