+ Reply to Thread
Results 1 to 6 of 6
Thread: Oil in fuel_HELP!
    jdtj63 is offline Rookie jdtj63 is an unknown poster at this point.  Don't let him/her around power tools just yet.
    May 2004
    Rock Hill, SC
    38
    Default Oil in fuel_HELP!
    I have oil in my diesel fuel and it keeps clogging my fuel filter. put in half gallon and already a gallon low. Anybody know what is going on?
    DD60 series engine
  2. #2
    magna19 is offline Rookie magna19 is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Apr 2009
    14
    sounds like injector cup seals in the head. also you can get antifreeze in the fuel that way also.
  3. #3
    randyc's Avatar
    randyc is offline Rookie randyc is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Feb 2004
    Florence SC
    34
    Bad injector o-rings. I had the same problem recently and had to replace all my injectors. $2500.00 job. Mine was a 3126B Cat.
  4. #4
    Windwalker is offline Board Icon Windwalker is a distinguished poster and probably helps little old ladies across the street. Windwalker is a distinguished poster and probably helps little old ladies across the street. Windwalker is a distinguished poster and probably helps little old ladies across the street. Windwalker is a distinguished poster and probably helps little old ladies across the street.
    Oct 2005
    Been there and gone...
    6,187
    Also, check for coolant in the oil pan, and oil in the coolant. You could have both. But oil, coolant, and fuel all seem to have a way of mingling at the injectors.
    Destroy the cities...
    and they will rebuild them.
    Destroy the farms...
    The bill has come due.
  5. #5
    bobwadas is offline Rookie bobwadas is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Aug 2009
    14
    Default wow
    Quote Originally Posted by randyc View Post
    you didnt need new injectors...these can last indefinately in the 3126...there is ni maint. replacement miles.
    these injecorts have a seal on top that gets over 5000 psi going thru...can be replaced w/injector installed..dont need to pull them
    Im not trying to downplay the shops advicce..but I worked with the engineers with the development of this engine..and needing 6 injectors at one time is nearly impossible !
  6. #6
    trucktool is offline Rookie trucktool is an unknown poster at this point.  Don't let him/her around power tools just yet.
    May 2009
    17
    Quote Originally Posted by bobwadas View Post
    ...the injector body can leak as well as the seals, so yes sometimes it is the injector that causes oil in the fuel.
    Those engineers should have told you that the maximum rail pressure on a HEUI system is 3,500psi not 5,000.
    6 failed injectors at once IS nearly impossible... but, how would you go about isolating that ONE bad injector??
+ Reply to Thread
