+ Reply to Thread
Results 1 to 14 of 14
Thread: Filter Wrench
    devildice's Avatar
    devildice is offline Senior Board Member devildice is on the right path.  You could probably safely loan them a quarter.
    Sep 2006
    San Antonio, Texas
    2,015
    Default Filter Wrench
    I know someone one here will be able to help me out.......I want to change the filter on my air dryer. But the problem is finding a filter wrench that will fit the diameter. I have those adjustable rubber strap kinds and broke not one, but two attempting to remove the old filter . So I would prefer to find the "good ole" metal strap kind.
    Any suggestions on where I can find one?
  2. #2
    Kranky's Avatar
    Jun 2006
    Wisconsin
    1,108
    I assume you're referring to one of the newer style air driers with the "spin on" filter.
    Use a chain wrench such as this to remove the old filter:
    Also make sure the air system pressure is entirely released before removing, or the O ring will blow out with a bang, and you could get hurt.
  3. #3
    Jumbo's Avatar
    Jumbo is offline Senior Board Member Jumbo is a distinguished poster and probably helps little old ladies across the street. Jumbo is a distinguished poster and probably helps little old ladies across the street. Jumbo is a distinguished poster and probably helps little old ladies across the street. Jumbo is a distinguished poster and probably helps little old ladies across the street.
    Aug 2006
    Northern Wisconsin
    2,102
    An auto parts store may have the wrench you need. Or Napa might carry heavier duty ones.
  4. #4
    devildice's Avatar
    Sep 2006
    San Antonio, Texas
    2,015
    Quote Originally Posted by Kranky View Post
    Yeah it's the spin on/off kind. That chain wrench looks like it would do the job. I thought about going "Old School" and pop a hole in it with a screw driver like we used to do on oil filters back in the day but am a little apprehensive to do so. Oh, and yeah I drained/released all the air out of the system before I tried with the rubber wrenches.
  5. #5
    devildice's Avatar
    Sep 2006
    San Antonio, Texas
    2,015
    Quote Originally Posted by Jumbo View Post
    You know, I always come across a NAPA but never need anything......now that I NEED a NAPA, go figure I can't find one
  6. #6
    Jumbo's Avatar
    Aug 2006
    Northern Wisconsin
    2,102
    Ebay shows 310 listings. Some look like what Kranky suggested.
  7. #7
    devildice's Avatar
    Sep 2006
    San Antonio, Texas
    2,015
    I didn't check Ebay. I was kind of hoping to get my hands on one while I'm out on the road. Hopefully I will come across a NAPA, Northern Tool, or some other place that might have them. If that doesn't work I'll just have to go to one of those places when I get back home.
    "Thank You" to the both of you for your suggestions, I appreciate it.
  8. #8
    Fredog is offline Senior Board Member Fredog is a trusted source of information and would probably pick up your dry cleaning. Fredog is a trusted source of information and would probably pick up your dry cleaning.
    Apr 2005
    North Georgia
    3,665
    napa has one that has a very heavy leather like strap and and 1/2" square fitting so you can use a 1/2" drive ratchet on it, I havent met a filter yet that it cant take off. you could probably get it at a truck dealer also
    it looks like this it's 22.50 at mytoolstore.com
  9. #9
    devildice's Avatar
    Sep 2006
    San Antonio, Texas
    2,015
    Quote Originally Posted by Fredog View Post
    That looks like it would do the jog too.......now it's just a matter of finding a place that carries it or the chain type. Thanks.
  10. #10
    Orangetxguy is offline Senior Board Member Orangetxguy is well-known and should trademark his/her name. Orangetxguy is well-known and should trademark his/her name. Orangetxguy is well-known and should trademark his/her name. Orangetxguy is well-known and should trademark his/her name. Orangetxguy is well-known and should trademark his/her name. Orangetxguy is well-known and should trademark his/her name.
    Jan 2007
    4,634
    I got one of those style wrenches for free last monday evening. Had my oil changed at the Petro in Shreveport. Found their wrench on the oil filter during an enroute check, the next morning. Also saw that they didn't change the filter!
    No...I did not stand there and watch them change the filter. I figured I shouldn't have to! Since I had the service done on monday night, tuesday morning I checked the oil, but I did not shine my flash light onto the filter!
    Got a new oil change when I got to the Petro in West Memphis AR that evening.
    The bad thing about finding that filter wrench....I also found coolant coming from the "weep hole" on my water pump. I ended up dropping my load at our Memphis terminal and getting the water pump replaced. 3 days for the right pump to show up....freaking Cat's!!
    Space...............Is disease and danger, wrapped in darkness and silence! Star Trek2009
  11. #11
    Apr 2005
    North Georgia
    3,665
    Quote Originally Posted by Orangetxguy View Post
    try speedco next time,when they are done, they take you to the truck and show you everything that was done.
  12. #12
    Larry227 is offline Member Larry227 is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Sep 2008
    British Columbia
    50
    Try not to tear it up too bad. I'm pretty sure there's a core charge on those dessicants. Could depend on where you buy them though.
  13. #13
    jonp's Avatar
    jonp is offline Senior Board Member jonp is on the right path.  You could probably safely loan them a quarter.
    May 2008
    North Carolina
    698
    I've got one like that and have used it for years. Pretty bullet proof and fits about everything. I think that I got mine in a wal-mart. Mine has a fabric strap to it and is a little frayed now but I swear by it. I've actually crushed an oil filter with it using a cheater bar.
  14. #14
    magna19 is offline Rookie magna19 is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Apr 2009
    14
    if i remember correctly a cat filter wrench fits them nicely.be carefull trying to spin them off since the body is aluminum,and the cartridges sometimes do not come off easy at all,if they havent been changed recently.i have spun quie a few off and boogered the threads on the housing,then its change the whole dryer off.
  15. This ad will disappear if you login
+ Reply to Thread
