+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 23
Thread: rear end leak??
    heavyhaulerss's Avatar
    Jan 2007
    north alabama
    1,186
    Default rear end leak??
    I just noticed my rear, rear had a film of oil around what I would call the pressure relief screwed into top side of rear. what is strange to me is, I have never seen it do this before, I always change rear oil every 6 months or 45,000 miles. wich ever comes first. I always checked fluid level & never had to add any. the rear has always been dry for 10 years now, maybe just a lil oil residue, barley ,slightly, but not like this. I replaced valve. still puts out oil only around that area of valve. it does not leak a lot out, but this is a first. changed fluid today nothing on mag plug. so why, all of a sudden would oil come out thru valve? also when I changed the fluid is was after running 104 miles at interstate speeds, I parked truck & within 10 min oil was draining & it was not real hot at all, just warm, not sure if that means anything or not.
  2. #2
    Larry227 is offline Member Larry227 is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Sep 2008
    British Columbia
    50
    Does it have a locker on it and if so have you been using it? If the answer is yes it could have a bad seal in the locker and when you engage the diff lock it is letting some air pressure into the diff and coming out the breather.
    That's the only thing that will literally force oil out of the breather. If it's not that and it's not ever low it's just breathing and I wouldn't worry about it. At least if it's getting a film there you know it's not plugged which would be worse.
  3. #3
    Jan 2007
    north alabama
    1,186
    thanks for the reply larry. my neighbor truck driver told me all the trucks at his co have the same thing. & most are new trucks. I have not used the p.d.l . I thought if a bearing was going out & heating up the oil to a high temp, that it would push some oil out, but as I said the oil is not hot when I checked just after shut down. I was just concerned, cause when I go over my truck & see something that I have not seen before. I think something's ready to give out on me. after 10 years & never being broke down on the road, I can't tell you how many times I saw something needing attn in my drivway, that if not taken care of would surley have left me on the side of the road. thats why I go over, around & under my truck every time I get back. sometimes that means every day if I do my dedicated daily runs.
  4. #4
    Jan 2007
    north alabama
    1,186
    WAIT A MINUTE!! I just remembered something. this may or may not have something to do with leak... I had the in dash pdl replaced cause it was leaking air. now that I think of it it was only after that point the rear leak occurred. coincidence or no? I dont know. I have not used the pdl, but.. if the shop that installed it, crossed the 2 air lines would that be the problem ? I know there was only 2 wires & 2 air lines. one top line, one bottom line. so maybe he put the botton on the top & vise versa. does that sound like it could have caused the leak? & how can I check to see wich line should go where, to check this?
  5. #5
    Sep 2008
    British Columbia
    50
    To test just take the airline off at the axle and see if air is coming out when the switch is off.
    If the seepage is on the #3 axle and the switch you replaced is for the power divider on the #2 axle it would not cause your issue. When you said rear rear end I'm assuming you meant the #3 axle. (I call #1 axle the steer). The switch being changed is probably a coincidence. I'm sure it's just On/Off anyways and makes no difference which line goes where.
    I'll ask the guys at work today if the bearings could cause that. They know way more than I do.
  6. #6
    Jan 2007
    north alabama
    1,186
    this is correct. the only reason I mention bearing is a person told me if the temp in the rear got to boiling temp & was too hot, that could cause the oil to come out of relief valve, & the only thing he could think of was if a bearing was going out that would raise oil temp. to be honest. when looking diff.. I dont know wich one gets locked. I assume one is always engaged & the other engages only when pdl switch is flipped.
  7. #7
    YerDaddy's Avatar
    YerDaddy is offline Board Regular YerDaddy is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Mar 2008
    @ my keyboard
    219
    No axle temp gauge? They are easy to add. Just one hot wire to a sending unit and ground the axle to the frame with another wire.
  8. #8
    Jan 2007
    north alabama
    1,186
    Quote Originally Posted by YerDaddy View Post
    it does not have a gauge. where would i put the sending unit?
  9. #9
    Kranky's Avatar
    Jun 2006
    Wisconsin
    1,108
    Quote Originally Posted by heavyhaulerss View Post
    It's not a relief valve, it's a vent.
    As was stated, it's important that the vent is checked often and cleaned out if necessary, because a clogged vent will allow pressure to build up inside the diff housing, resulting in blown wheel seals or blown pinion seal.
    Have you changed to a different brand or type of rear end lube recently?
    From mineral to synthetic?
  10. #10
    Jan 2007
    north alabama
    1,186
    vent is new. it leaked with the old one. it leaks with the new one. same type lube in rear for 10 years. changed every 6 months/ 45,000 miles.
  11. #11
    Jumbo's Avatar
    Jumbo is offline Senior Board Member Jumbo is a distinguished poster and probably helps little old ladies across the street. Jumbo is a distinguished poster and probably helps little old ladies across the street. Jumbo is a distinguished poster and probably helps little old ladies across the street. Jumbo is a distinguished poster and probably helps little old ladies across the street.
    Aug 2006
    Northern Wisconsin
    2,102
    I did a quick walk around the trucks (4) in our terminal. Everyone has a little oil around that breather. Is it possible that the breather was plugged with gunk for so long and finally got freed up so the oil could come out? The world may never know.
  12. #12
    Jan 2007
    north alabama
    1,186
    truck went into the shop tues. shop mgr said leak was not normal. most likely a bearing going out. a lot of drivers told me not to worry, that it was normal. if thats the case then the rear has been broke for 10 years & now it's normal. lol. cause no leak for 10 years until now. anyway the shop folks are hometown folks & they will be honest about what the problem is. will post when I get fixed
  13. #13
    Jan 2007
    north alabama
    1,186
    got back out from shop.. a couple of bearing were pitted & really needed replaced. I asked if that would cause oil to come out of vent? he said yes. he said everything else, gears e.t.c. looked good. have not drove but 10 miles from shop, well see next week when I go on road if prob solved.. thanx for replies
  14. #14
    Sep 2008
    British Columbia
    50
    I can't imagine pitted bearings causing the oil to come out but I haven't seen everything. Seeing how it was ten years old there was a 99% chance they would find some wear on something. I'm curious to see if it fixes the oil thing.
  15. #15
    Kranky's Avatar
    Jun 2006
    Wisconsin
    1,108
    I'm skeptical too.
  16. #16
    Jan 2007
    north alabama
    1,186
    they told me the only thing to make oil come out of the vent was heat. if the oil in the rear got too hot it would come out the vent & the bearing going out will cause the oil to get hotter than it normally would. it cost $1045 to get the work done. I hope to have a load mon, the 13th. if I do I will surely know when I get back.
  17. #17
    boneebone is offline Board Regular boneebone is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Nov 2004
    Somewhere in this World
    328
    If you have a leak in your rear you didn't use enough toilet paper.
  18. #18
    Jan 2007
    north alabama
    1,186
    finally got to drive. drove 380 miles. oil still coming out from vent. I guess I'll just drive it like it is. I cant afford another misdiagnosis. maybe it will not be a problem. the bearings may very well needed replacing. though it did not solve the oil vent prob. the rear has never had anything done to it ever except oil changes since 1995. so maybe I am lucky. thanks for all the input.
  19. #19
    Sep 2008
    British Columbia
    50
    I'm sure getting it re-bearinged was money well spent even if it didn't stop the seepage. One less thing you'll have to worry about now.
    Just keep the oil level with the plug and keep an eye on it. If you don't lose a lot I would say it's just needing to vent. At least it's venting there and not blowing seals.
  20. #20
    Jan 2007
    north alabama
    1,186
    Thanks for the optimistic view Larry. I cannot complain. after 11 years & over 1.2 mil I have gone farther than most o/o's. the trans went 1.1 mil from the factory before I had to do anything to it, & then all I did was have clutch put in & it is still going. got over a mil before doing anything to any part of truck, except the usual wear & tear items. the engine has yet to be rebuilt. so after paying $15,000 cash for it & having it all this time. with no more than I spent on it, I consider myself 1 of the lucky ones. have a great wknd folks...
+ Reply to Thread
