+ Reply to Thread
Results 1 to 14 of 14
Thread: Differential not locking!
    matcat's Avatar
    matcat is offline Senior Board Member matcat is on the right path.  You could probably safely loan them a quarter.
    Sep 2007
    Manchester, NJ
    1,469
    Default Differential not locking!
    When I was leaving a warehouse today, I was going to pull out on the street, but I wasn't moving! Couldn't go forward, or backwards. Checked it out, my rear drive axle was 3 inches off of the ground because of the slope of the exit. So I went to lock the differential, and no dice. The dash computer showed it was locked, but it was not. Any ideas why it might not be locking?
    My Trucking Blog: http://matcattruckin.blogspot.com/
    Website I am making for drivers: http://www.4thedriver.com
    As I sit looking all around,
    Confusion and uncertainty is all I found.
    The answers are there,
    But I do not know where.
    Optimistic and hopeful dreams,
    Are all I have so it seems.
    The future I do not know,
    So all I can do is take it slow.
    But I do know it will work out,
    So I wait and watch without a doubt
  2. #2
    Aug 2005
    jackassville (winnipeg, mb)
    3,181
    Did you lock the power divider, or the axle? Do one or two of your axles have lockers?
  3. #3
    matcat's Avatar
    Sep 2007
    Manchester, NJ
    1,469
    Quote Originally Posted by allan5oh View Post
    Let me clarify, the interlock, so that both my drives would drive.
  4. #4
    Aug 2005
    3,181
    You sure it wasn't locked, you know how they work?
    You can definitely still have wheels spin with the power divider locked.
  5. #5
    matcat's Avatar
    Sep 2007
    Manchester, NJ
    1,469
    Yes I am 100% sure it wasn't locking.
    The rear drive axle was completely off the ground, so it had no contact of any kind with the ground, it would just spin. The front drive axle, was firmly on the ground. If it was locked in place, the front drive axle would of caused me to move, looking in the mirror only the rear drive axle was spinning, ontop of that when you flip that switch, you can actually hear it lock in place, there was no sound, I had someone stand next to it while I flipped the switch to hear it, no sound. I know it is air powered, so I am thinking maybe the air line is broken going to it? I don't know.
    What I do know, is that if you flip that switch, both drive axles are supposed to turn!
  6. #6
    Aug 2005
    3,181
    You're absolutely right, was there any air leaks?
    So none of the four front drive tires were moving at all?
    A trick you could've done is back off the front drive brakes, and release the spring brakes. This forces the torque to go to the front drive tires.
  7. #7
    matcat's Avatar
    Sep 2007
    Manchester, NJ
    1,469
    Yeah there was no movement of any kind on the front drive axle. You mean let off the clutch a little with the breaks engaged then release the brakes? I will have to try that next time.
  8. #8
    matcat's Avatar
    Sep 2007
    Manchester, NJ
    1,469
    At first I kept putting concrete blocks down under the working drives, which did give me about 6 inches of forward movement, but eventually I lost all my progress when I rolled back to where I was initially . Luckily they where taring up a part of the lot, and there was a crew there with a forklift. I asked them to push my trailer with the forklift, and that worked, pushed the entire rig forward until the working drive axle was back on terra firma.
    That would of been really silly to call for a tow just because of a small slope leaving a warehouse lot!
    But as for my original post, I am wondering if it is as simple as a airline, and if it is how hard is it to trace and fix it. Also as far as airleaks go, the funny thing is I do notice an air leak. But not in the rear. It is coming from the passenger side up near the stear somewhere. I checked out the air bag but I can't pin point it. I am pretty sure it isn't the air bag because all the air bags stay inflated at proper level, no one airbag is deflating any faster then the others. Though the air does run out fairly quickly when the truck isn't running. If I have it shut off for a good ten minutes, the air will drain down to about 55 PSI. Though it never drains enough to cause the trailer brakes to pop! Usually when I park I just pop the tractor brakes, and leave the trailer brakes disengaged. Even sitting for 10 hours with the truck not idling, the trailer never pops. The air will get down to about 50 to 55 psi and stay there.
  9. #9
    matcat's Avatar
    Sep 2007
    Manchester, NJ
    1,469
    As a matter of fact I am going to do a brake test right now to see if the trailer brakes will pop... Yeah they popped at about 20 psi. Truck is doing some wierd things though, wierd noises and shimmies now that the air is completely gone, I am just guessing it is the air bags settling down.
  10. #10
    Aug 2005
    3,181
    Quote Originally Posted by matcat View Post
    No I meant disable the front brakes from working at all by backing them off. Then pull OUT the yellow button and leave it out.
    This forces the torque to go to the front axle, since the rear is locked via the brakes. Traction control systems do this in a different manner.
  11. #11
    matcat's Avatar
    Sep 2007
    Manchester, NJ
    1,469
    Not quite sure how you would do that. I just built the air up to 125 psi, shut the truck off, and it dropped to 100 psi in about a minute.
  12. #12
    Jumbo's Avatar
    Jumbo is offline Senior Board Member Jumbo is a distinguished poster and probably helps little old ladies across the street. Jumbo is a distinguished poster and probably helps little old ladies across the street. Jumbo is a distinguished poster and probably helps little old ladies across the street. Jumbo is a distinguished poster and probably helps little old ladies across the street.
    Aug 2006
    Northern Wisconsin
    2,102
    Take off the air line that leads to the lock and see if air comes out when you flip the switch. It is possible the the lock is frozen from non use.
  13. #13
    matcat's Avatar
    Sep 2007
    Manchester, NJ
    1,469
    Quote Originally Posted by Jumbo View Post
    I'll try that next time im sitting during the day. Its a pain to find it though with the catwalk that covers the entire frame over it, probably would have to drop the trailer to get at it.
  14. #14
    heavyhaulerss's Avatar
    Jan 2007
    north alabama
    1,186
    the lever in the dash that locks the pdl may be leaking. take the 2 screws out & spray some soapy water on the air line going to it, then flip the switch back & forth & see if it leaks.
  15. This ad will disappear if you login
+ Reply to Thread
