My million mile 2001 Volvo with a N14 Cummins now has 1.1 million miles. The top end and electronic injectors are original. Should I be doing any preventative repairs to the top end?? I was thinking about replacing the rear two injectors (hard to access ) and carry them as spares as I believe I could replace the front four on the road if needed. Do the elecronic injectors fail destructively( fall into the cylinder?!)
Do rocker arms fail...or Valve springs, valves etc.
The truck is running good.. 5.5 to 8 miles per gallon
I have no problem doing $1000.00 preventative repairs! $1000.00 at home equals $3000.00 on the road! (or more)
Semi-educated guesses accepted!
If I did it correctly I also have attached a picture of my Genset install.
Bill Menominee, Mi
