I'm green as a gourd so any help will be appreciated. The clutch on this truck has been very stiff,catching, and generally impossible to disengage smoothly. We're loading hoppers and it requires fine movements not jerking around. 1st mech. on monday said it needed adjusting so he adjusted it. No change. 2nd mechanic on tuesday said it needed greasing. The truck has 1 of them automatic greasers. He pulled the fitting on the linkage bushing and it was dry so we inserted zerk and greased manually. We also greased the shaft and throwout bearing. This helped. However I have noticed that the clutch linkage doesn't kick the pedal out to it's full throw. There's about 1 1/2 inches of free play but you have to reach your toe under it and pull it up. Then it will stay otherwise no free play. I told the boss I thought this would wear the clutch disc constantly. My question is whether a linkage adjustment will fix this?? If so how do you go about it? Thanks.
