+ Reply to Thread
Results 1 to 4 of 4
Thread: Odd coolant test strip results
    Aug 2005
    jackassville (winnipeg, mb)
    3,181
    Default Odd coolant test strip results
    Green coolant, using luberfiner test strips. The colors are fine, nitrites are good, freeze point is -60, and ph is 8(whatever is in the middle).
    But the nitrite test is very spotty, hard to explain. Very small dots everywhere sort of. I've never seen it do that, and I use the same test strips all the time.
    Coolant is maybe 2 years old, changed the additive filter 8 months ago or so. Maybe I should just change to chevron delo ELC(million miles!).
    But I'm still wondering what caused that.... oil?
  2. #2
    solo379's Avatar
    solo379 is offline Senior Board Member solo379 is on the right path.  You could probably safely loan them a quarter.
    Feb 2004
    3,611
    I don't know Allan. But i do that "flash and fill" every two years anyway!
  3. #3
    Jan 2008
    In the back of your mind
    421
    I would re-do with some new test strips to eliminate the possibility that the strips are weird first.
    Then I would start showing them to people whose opinions I repected & asking them if they had ever seen anything like it before.
    If you're getting oil in your coolant, you should have some signs of coolant in your oil, maybe try an oil analysis to rule that out?
    Does anybody offer a send in type coolant analysis that might offer more info?
    Or just drive it til it pukes.
    The Big Engines
    In the Night-
    The Diesel on the Pass
    -Jack Kerouac, "Mexico City Blues"
  4. #4
    Maniac's Avatar
    Maniac is offline Senior Board Member Maniac is on the right path.  You could probably safely loan them a quarter.
    Sep 2004
    Northeast
    956
    I use Blackstone labs for my oil, they may do coolant also
    Blackstone Laboratories
+ Reply to Thread
