+ Reply to Thread
Results 1 to 5 of 5
Thread: CB radio
    marcel27208's Avatar
    marcel27208 is offline Senior Board Member marcel27208 is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Aug 2006
    salisbury,NC
    1,049
    Default CB radio
    ive got a galaxy 959 and always questioned why it didnt work as good as i thought it shouldve. when i turn my blinkers on i can hear them on my cb?? could it be my coax? where do i get a good coax from???? And i dont have a wide range either...cant get out very far or hear very far??? anyone help
  2. #2
    jonp's Avatar
    jonp is offline Senior Board Member jonp is on the right path.  You could probably safely loan them a quarter.
    May 2008
    North Carolina
    698
    You should be able to get maximum grade coax at any Radio Shack. Thats what they went into business for as a Radio Shack is slang for the place a person has his Ham Radio set up. It sounds more like a grounding problem to me although the coax won't hurt.
  3. #3
    Shnerdly's Avatar
    Shnerdly is offline Member Shnerdly is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Dec 2008
    The Frozen Tundra of Minnesota
    85
    Yeah, as jonp said, it sounds like a ground problem on the radio. You could try a temporary pair of wires directly to the battery and see if that fixes the problem. I would recommend at least 14 guage wire and a fuse at the battery end. Be careful not to pinch the wires in a door or something. They could short and start a fire if you don't fuse the wire.
    Colt: The original point and click interface.
    Gun Control isn't about guns, It's about Control.
  4. #4
    Aug 2006
    salisbury,NC
    1,049
    ok thanks! if its a ground how do i fix that???
  5. #5
    jonp's Avatar
    May 2008
    North Carolina
    698
    You can follow the ground terminal of the batteries to see where it attaches to the frame. See if there is rust there, if the strap is frayed or loose or whatever. You can add a second grounding strap yourself and attach it to a different place. BE CAREFUL DOING THIS! The voltage from a truck will melt your shoes. Always remove the positive line to prevent any problems.
    If you have a truck that has the pos/neg studs on the dash you can run a ground from there yourself and attach it to any bolt on the truck that has bare metal.
+ Reply to Thread
