+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 28
Thread: location of t.p.v
    heavyhaulerss's Avatar
    Jan 2007
    north alabama
    1,186
    Default location of t.p.v
    Does any one have any idea where the T.P.V. is located on a 95' intl cabover? was told I may need one. the original one has never been changed. so far the truck shop nor the intl dealer can tell me where it is. shop cannot find it. 3 intl dealers & the shop said it has to have one, but dont know where it is located. and no it is not located at the back of the cab. (not refering to the dash knob park brake.)
  2. #2
    Blind Driver's Avatar
    Blind Driver is offline Senior Board Member Blind Driver is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Apr 2006
    New Albany, IN
    540
    what is this TPV you speak of?
  3. #3
    pdm
    pdm is offline Member pdm is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Feb 2008
    Ontario, Canada
    83
    Can you follow the lines back from the glad hands? They have to come from the tractor protection valve.
    You can't fix stupid......
  4. #4
    Jan 2007
    north alabama
    1,186
    I have not looked extensively myself. the shop talked to a few dealers, one sais it may be behind drivers seat. not there. one said in drivers side pocket, not there. had cab jacked up, looked everywhere. had kick panels off near foot brake pedal, not there, had entire dash off, from speedo all the way to pass side area, not there. the shop had already ordered the valve, but sent it back when they could not locate the t.p.v. all the people we talked to told us where it might be or should be & had looked in all those places, nothing.
    symptom.. doing brake check.. both gauges at 120 psi engine off both yellow & red knob in start pumping brake pedal air tank #1 starts dropping twice as fast as tank #2. gauge # 1 goes to 5-10 lbs. tank . #2 at this time at 60-65 lbs both knobs still in keep pumping brakes, tank 1 bottoms out, no psi in tank . tank 2 after several more pumps gets to 20 lbs then red knob pops, pump brakes a lil more to almost o psi on tank #2 & yellow pops out.. this is what prompted me to replace t.p.v. as advised. buzzer & light work o.k.
  5. #5
    pdm
    Feb 2008
    Ontario, Canada
    83
    maybe its fastened to another valve, like the ford louisvilles were. I'm wouldn't expect replacing the tpv to change anything with your air based on your description though. The tpv keeps air from flowing out the service line to the trailer when the red button is popped.
  6. #6
    cdn
    cdn is offline Rookie cdn is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Feb 2008
    8
    follow the trailer lines back down the frame they have to go to the tvp.
  7. #7
    Jan 2007
    north alabama
    1,186
    Quote Originally Posted by pdm View Post
    thanks.. these d.o.t inspectors have different opinion on what is supposed to work & how it is supposed to work. no violations, just a warning to get fixed. if my red button is in & truck running or off, & glad handle pulled for trailer air, red buttom pops at 40-45 or so & when it pops air does not leak it holds. when the d.o.t watched # 1 gauge drop off twice as fast & bottom out, without any one of dash breaks poppin out until only air gaige #2 got to be 20 lbs or so, said it was T.P.V.
  8. #8
    Jan 2007
    north alabama
    1,186
    Quote Originally Posted by cdn View Post
    thank you.. wil get my microscope & my spotlights out to locate.. i'm not replacing if that part is not defective. even if that is not the problem..still want to know where it is at though.
  9. #9
    pdm
    Feb 2008
    Ontario, Canada
    83
    Do the guages come down together if the pedal is pumped slower? I would look for something in the air supply to the foot valve. The foot valve is fed from the primary & secondary tanks through a double check valve & sounds like tank #2 doesn't supply air as fast as number 1. The lines can be a little tricky to trace, maybe there's a kink or restricyion somewhere
  10. #10
    Jan 2007
    north alabama
    1,186
    no matter how slow or fast I pump brakes, tank # 1 goes down faster. even when driving & braking the # 2 tank starts to come down off 120-110 only when the # 1 gauge get to 90 or so.
  11. #11
    pdm
    Feb 2008
    Ontario, Canada
    83
    Think i'ld make sure the guages were accurate & worked properly. do they build up together? Another thing to check might be the lines going to the guages.....is one kinked somewhere? Then look at lines & valving from the tanks to the foot valve etc. I just don't see a tpv changing anything. Has it always been like this?
  12. #12
    Jan 2007
    north alabama
    1,186
    the gauges are correct. they build up at same rate. well... the one that is the lowest.. # 1 will start to build back up & when it reaches same psi as tank 2 then they both move at same rate. it has not always been like this. I cannot find any leakes anywhere. if i apply pressure to brake pedal & hold, the gauges drop just a couple lbs & hold. as if there is no leak in brake chambers, e.t.c.
    I may have found where the tpv is.. the air lines from the gladhands go thru drivers side side box & under floorboard under drivers seat. there then is a valve mounted to the underside of floorboard with a lot of air lines coming from it going to foot valve & other places. there are no leaks or kinks under dash or near gauges or air lines there. i replaced all air valves on truck... leveling valve, front valve wich has a pop off on it,mounted near front bumper on frame, the one on the front rear and going to brake chambers,, & the big one going to all four brak chambers on tractor. had replaced 2 brake chambers a while back that had very slight leak. ( had to wait a couple hours to see leak.) still made no noticeable difference. my biggest concern is #1 tank going too low while having to brake often. whe driving especially downhill & braking due to some rough roads my foot will slightly bouce on the brake pedal & thee # 1 tank will drop like crazy. I gues just one of those things that will dumbfound me until fixed. thanks for all the feedback..
  13. #13
    cdn
    Feb 2008
    8
    Default picture of t.p.v.
    hxxp://www.tonystruckparts.com.au/tp3.jpg replace xx with tt and take a look your t.p.v. should look like this
  14. #14
    YerDaddy's Avatar
    YerDaddy is offline Board Regular YerDaddy is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Mar 2008
    @ my keyboard
    219
    How does a brake chamber take a couple hours to leak? They don't get air pressure unless you apply service brake. You held your foot on the brake that long?
    Have you shut off truck in quiet place (not a noisy truck stop) wheels chocked, parking brake off and have someone depress and hold brake and you walk around truck and listen for leaks? Quick release valves?
    Are you sure you air compressor is adequate? Kinks in line? Air dryer in working order?
  15. #15
    Jan 2007
    north alabama
    1,186
    Quote Originally Posted by YerDaddy View Post
    placed concrete block on brake pedal & went on to other things, then checked for leaks later. the leak & the bubbles were so small, it almost was not worth changing.
    I had the old compressor taken off cause it took forever to build air. I let the shop take it off & I took it to truckpro, got an exchange & brought to shop to have them put on. the new compressor did not build air any better than the old one..... that was a year ago. new air dryer 4 months ago. after the down time. i was frustrated & wanted my truck & get back to work & just deal with the slow build of air, but this new problem of one tank going down too quick & almost by itself has added to the exisisting problem. at 120 lbs. & truck off by 8 hours both tanks are on 0 psi. i have put expensive leak detector on everything visible. no leaks. this stuff cost 10.00 a quart. when bubbles are produced from a leak the bubbles remain for 10-15 hours & if their is any condensation or moisture rain e.t.c it will be visible for 24 hours. I wish i could submerge entire truck in leak detector.. lol
  16. #16
    Jan 2007
    north alabama
    1,186
    I finally found tpv.. it was under floorboard just in front of drivers seat. had to take off rubber mat & aluminum floor pans & 50 screws to get to it. 2 dozen air lines uner there. a hell of a place to put it. will be checking for leaks in all the connectors & lines as well as the tpv itself the next day or 2
  17. #17
    Oct 2006
    Nb
    794
    Quote Originally Posted by heavyhaulerss View Post
    A service side leak that causes one air reservoir to empty twice as fast as the other WILL NOT require leak detector and bubble inspection to find that air loss -- it should be very obvious.
    Does the 'excessive' air drop occur before or after you release the service brake application?? If the drop occurs BEFORE you take your foot off the pedal, it would seem more like a problem of air res capacity, or excessive pushrod stroke... this type of thing. If the drop occurs only AFTER you've removed your foot, then the air loss would more likely be escaping through a sticking air valve exhaust port, or something of that sort.
    ...I wouldn't recommend taking technical advise from a DOT officer.
  18. #18
    Jan 2007
    north alabama
    1,186
    Quote Originally Posted by bob h View Post
    yes Bob . i thought this leak would be easy to find too. i can hold the brake pedal down & it's o.k., when i pump brakes is when #1 tanks drops significantly faster. sooo, holding, no drop ,releasing no drop, its when i pump a 2nd time that it goes down, then the 3rd pump, e.t.c. & after a few pumps the # 1 tank is far below the # 2 tank. i replaced all air valve ports. i do know that there is air that comes out from a huge valve that seems connected to the brake pedal with a lot of air lines to it. thought air only escapes when taken foot off brake & air comes from under a thin wafer like rubber washer with a smal screw in the middle holding it in place. though this may be normal cause the rubber disk is plyable to pull away but pulls back into place when released. I also still have to find why i lose all my air from 120 psi to 0 after 7 hours or so. i wouldnt mind taking it in some where if they could find it & not keep my truck for days & then tell me to try it out & see how it does now ,kind of thing.
  19. #19
    Kranky's Avatar
    Jun 2006
    Wisconsin
    1,108
    Relay valve.
  20. #20
    RockyMtnProDriver's Avatar
    RockyMtnProDriver is offline Senior Board Member RockyMtnProDriver is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Jun 2005
    Somewhere between Western Canada and Texas/California
    1,624
    They should drain at different rates. One tank is larger than the other. Now the issue is which one is draining first. If the Secondary tank (smaller tank) is draining first, then that is probably right, if the primary tank (larger tank) is draining first, then there would be an issue.
    Do this test. Charge up your air tanks, make sure you know which is the primary tank (largest tank) and drain it. The gauge which still has air in it, will be the secondary tank.
    Primary tank runs the rear drivers service brakes (more of them, needs more volume) and the Secondary tank runs the front axle service brakes (less of them, needs less volume)
    A two way check valve connects both the Primary and Secondary tank and this gives you Blended Air which is what supplies the Spring Brakes and the Trailer Supply line.
    Also, on the original question of the post, Yellow dash valve does not need to pop out on the tractor protection test to meet standards and the Red dash valve needs to pop out no lower than 20 PSI on the test.
    This is the test you need to pass to stay legal in British Columbia and I think it is pretty much standard across North America, although it might be different for your jurisdiction.
    With the engine off and the tanks at maximum reservoir pressure
    * push both yellow and red dash valve in
    (it is a good idea to have the key on (engine off) to see when your low air warings come on)
    * make full brake applications until Red Dash Valve pops out
    * go to the back of the trailer and make sure the trailer brakes have applied
    * take off the supply line and see if there is an air leak
    * take of the service line and do a full brake application to see if there is a service leak
    And yes, often the Inspectors DO NOT KNOW, or will give you an opinion, of what the law is. Unfortunately they are the ones writing the ticket.
+ Reply to Thread
