+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 24
Thread: restart procedure
    Bigmon is offline Senior Board Member Bigmon is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Jan 2006
    North East
    1,085
    Default restart procedure
    I let someone use my truck and they ran out of fuel. Put fuel in and won't start. I didn't want to keep cranking it and drain the batteries. I there a procedure to restart? It's a S-60 engine.
  2. #2
    Aug 2005
    jackassville (winnipeg, mb)
    3,181
    Pull off the fuel filter and refill it. There may be a hand pump, and places to "crack" open the fuel lines. Call a detroit shop.
  3. #3
    marylandkw's Avatar
    marylandkw is offline Senior Board Member marylandkw is a trusted source of information and would probably pick up your dry cleaning. marylandkw is a trusted source of information and would probably pick up your dry cleaning.
    Sep 2005
    Maryland
    733
    Quote Originally Posted by allan5oh View Post
    X2
    There is not a way around it either. No amount of cranking will do anything other than destroy your starter. If this is beyond what you can or will do, it should only take a good roadside mechanic 10 minutes or so to get you going again.
    I am ashamed to admit that if you had a Cat I would be able to detail the procedure step by painful step from way too much experience.
  4. #4
    Aug 2005
    3,181
    as would I, if you had a Volvo.
  5. #5
    cdn
    cdn is offline Rookie cdn is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Feb 2008
    8
    electric fuel pump plumed into the feul line just before the mechanical fuel pump turn pump on wait about 2 mins for fuel pump to pressure up and start engine, run for about a min or so then disconnect the electric pump and rehook the line from the tank nack up to the mechanical fuel pump, has worked for us for yrs when ever a detroit has run out of fuel.
  6. #6
    Jan 2006
    North East
    1,085
    Thanks for the input. Glad I didn't keep cranking it. It has a Davco filter. Looks like there is a cap that comes off the top to fill it. Davco says this is the procedure when you first install a Davco.
  7. #7
    Aug 2005
    3,181
    That probably won't fix it. You need to purge the air.
  8. #8
    Jan 2006
    North East
    1,085
    I put fuel into the filter and it started after a few cranks. Thanks for all your help.
  9. #9
    Aug 2005
    3,181
    You got lucky!
    Usually when it's completely bone dry, just filling the filter won't do anything, as the pump cannot suck it up anyways.
    I'm willing to bet it wasn't completely dry.
  10. #10
    Logger is offline Rookie Logger is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Jan 2007
    Dunedin New Zealand
    13
    You were lucky mate. I run one dry in a K104 several years ago and it was a major PITA!!! We needed an electric fuel pump to pressure diesiel through the fuel lines and if memory serves there were two bleeders that had to be opened to get the fuel right through the system. It definitely wasnt a 2 minute job. First sign that the sucker is about to run out just pull over and shut down ASAFP!!
    Just because yer paranoid doesnt mean their not out ta get ya!!
  11. #11
    jonp's Avatar
    jonp is offline Senior Board Member jonp is on the right path.  You could probably safely loan them a quarter.
    May 2008
    North Carolina
    698
    I've always been able to fill up the fuel filter, crank till its dry, then fill it up and crank etc...and its started for me. Made sure to let the starter cool between cranks but has always worked.
  12. #12
    Rev.Vassago is offline Guest Board Icon Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name.
    Apr 2006
    The other side of the coin
    9,411
    Don't people use Ether anymore? I've started bone dry engines on it in the past after running out of fuel. Granted, it wasn't my truck either.
  13. #13
    Aug 2005
    3,181
    Ether belongs in the garbage can.
  14. #14
    Jan 2006
    North East
    1,085
    Smile
    Where would you put Ether ? I don't have a carburetor and I don't have the # to call Steve Booth.
  15. #15
    YerDaddy's Avatar
    YerDaddy is offline Board Regular YerDaddy is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Mar 2008
    @ my keyboard
    219
    Spray it in the air intake.
    Used to be able to spec an ether injector on a new truck for the cold climates.
    Back in the 80s sometimes we'd reach out the window while pulling a hill and spray some ether into the air intake on them old Mack 237s for a little more power and some laughs.
  16. #16
    Apr 2006
    9,411
    You can actually get a truck to run on ether. It ain't pretty, but it will work. I know that with the newer engines, I've heard that it will do damage to all the special gizmos inside the engine, but it will work in a pinch.
  17. #17
    Aug 2005
    3,181
    If used incorrectly, it will blow gaskets everywhere, maybe even break a few rings. It's very violent stuff.
  18. #18
    Apr 2006
    9,411
    That's half the fun though.
  19. #19
    cowdoc is offline Rookie cowdoc is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Feb 2008
    44
    I ran out last spring. boss sent a mach. with fuel. 55 series Detroit and we couldn't get it to pick up. Tiny shot of ether and it cranked right up. That brings up another point. We got 2 2002 9400 IH's this spring. They were Safeway trucks in California and they don't have block heaters. Do they still make those that slip in the dipstick hole?? We need heaters.
  20. #20
    YerDaddy's Avatar
    Mar 2008
    @ my keyboard
    219
    Quote Originally Posted by cowdoc View Post
    There's just a pipe plug where a fuel heater would go. Buy a fuel heater for your engine and pull the plug and stick the heater in the hole. Drain the coolant first.
+ Reply to Thread
