A less "violent" method is to pull the air filter element out and spray a little WD40 into the air intake as you crank it. Then just keep spraying a controlled amount of WD40 (just enough to keep the engine going) until it picks up the fuel and runs on it's own.
WD40 doesn't create those detonation type noises the way ether does. It's much more gentle on the pistons.
Don't just spray it in the air cleaner without removing the filter element though, or the paper filter will get all oily.
