+ Reply to Thread
Results 1 to 11 of 11
Thread: MPG Drop and Smell of Anti-Freeze
    Papa Rick's Avatar
    Papa Rick is offline Board Regular Papa Rick is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Sep 2006
    North Alabama
    476
    Default MPG Drop and Smell of Anti-Freeze
    This has been going on for 2 weeks now, my mpg went from 5.2 to 4.2, and I keep smelling anti-freeze like it is leaking somewhere, but can find no leaks anywhere, and have not had to add any anti-freeze before, or during this time.
    Another thing that is puzzling is when parked overnight now my air pressure will drop down to 30lbs, and if left over the weekend, it goes down to 0. It use to drop to 90 to 100 prior to this.
    I did have a problem getting water in the system, but have changed filters 4 times in the last 3 weeks and no show of water now.
  2. #2
    boneebone is offline Board Regular boneebone is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Nov 2004
    Somewhere in this World
    328
    You could have a head gasket leak that is leaking down the side of your block, but since the block is hot when it is leaking, there are no signs of leaking because it is evaporated already.
  3. #3
    sidman82's Avatar
    sidman82 is offline Senior Board Member sidman82 is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Jun 2006
    Long Island,NY & GA
    526
    Your probably like me and notice any little smell or hear any noise even if it's not there. It's been getting cooler and mabye using the heat is making it smell a little more like antifreeze.
    That also is why the air is losing pressure. Temp drops will make that happen. Contraction of air hose fittings and the like make small amounts of air leak out. Not a problem in warmer weather, because the fittings are not contracting.
    My first inclination anyway.
    I can use power tools, and I'll think about doing your dry cleaning if the rates are good.
  4. #4
    Blind Driver's Avatar
    Blind Driver is offline Senior Board Member Blind Driver is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Apr 2006
    New Albany, IN
    540
    My truck would hold air pressure over a weekend. Now it's at 20lbs overnight.
  5. #5
    heavyhaulerss's Avatar
    Jan 2007
    north alabama
    1,186
    Smile
    Well since no one can identify the original post problem including me.. I'll just add to the list of problems & say mine leaks down to 20 lbs overnight too & i cannot find the leak. soaped everything with special leak detector that when it bubles the bubbles stay there for 12 hours & still nothing. so i'm lost on that one too.
  6. #6
    Oct 2006
    Nb
    794
    Quote Originally Posted by Papa Rick View Post
    Winter fuel mpg?
    Are you smelling a/f inside or out? Is the antifreeze going down at all in the expansion tank? Have you checked the oil for contamination? Look at your hose connections, bottom corners of rad, etc. Try tying a plastic bottle to your radiator cap overflow hose to see if it collects antifreeze. When a/f leaks externally, on hot components it will usually leave a white, chalky residue behind.
    If you leave it out overnight, your RES air might be getting cold… ; )
  7. #7
    Papa Rick's Avatar
    Sep 2006
    North Alabama
    476
    Still have not found the reason for the mpg drop, but went to check my Truck out today after it sat for 3 days and when I pulled up I noticed it was leaking AF underneath? That was not a good feeling but opened the hood and found the O rings around my oil cooler were wore out and it was leaking from there.
    I guess this is the reason that I could not find the smell of AF as it was such a small leak until it finally gave way. Have to wait until Monday and get the parts for this. I hope this fixes my smell of AF, but still stumped by the drop in mpg, as I have not a clue to what is going on here.
    11-30-2008 02:21 PM
    bob h
    Winter fuel mpg?
    Thought this might be the problem to start with, but it did this last year when fuel was switched over to winter blend, but after a couple of weeks it came back up and stayed there until now. Hard to figure on this one!
  8. #8
    Nov 2004
    328
    11-30-2008 02:21 PM
    bob h
    Winter fuel mpg?
    When is the last time you had a overhead done?
  9. #9
    Orangetxguy is offline Senior Board Member Orangetxguy is well-known and should trademark his/her name. Orangetxguy is well-known and should trademark his/her name. Orangetxguy is well-known and should trademark his/her name. Orangetxguy is well-known and should trademark his/her name. Orangetxguy is well-known and should trademark his/her name. Orangetxguy is well-known and should trademark his/her name.
    Jan 2007
    4,634
    Question
    Quote Originally Posted by boneebone View Post
    And the charged-air preassure checked?
    Space...............Is disease and danger, wrapped in darkness and silence! Star Trek2009
  10. #10
    Windwalker is offline Board Icon Windwalker is a distinguished poster and probably helps little old ladies across the street. Windwalker is a distinguished poster and probably helps little old ladies across the street. Windwalker is a distinguished poster and probably helps little old ladies across the street. Windwalker is a distinguished poster and probably helps little old ladies across the street.
    Oct 2005
    Been there and gone...
    6,187
    That "charged air" could be a clue. I was not getting very good fuel economy on the truck I'm driving. Then, about two months ago, it blew the turbo. Since it's been replaced, it's been doing quite well on the economy. More than a mile a gallon more. You might also check that system for leaks.
    Destroy the cities...
    and they will rebuild them.
    Destroy the farms...
    The bill has come due.
  11. #11
    Papa Rick's Avatar
    Sep 2006
    North Alabama
    476
    Got the O Rings replaced on the Oil Cooler Tuesday, and have not driven it but 150 miles since then, so not sure but keeping my fingers crossed about the smell of Antifreeze.
    This shop found the air leak, and it was 2 different places, one was the pop off valve on the air compressor was not closing up all the way, not much of a leak, but enough over night to let it come down. And the 2nd place was on a valve hook up for an air line to air my tires up with. Both of these I checked, but never saw anything, but the shop tech told me he had some soapy solution that was made to stick on whatever it was sprayed on and show much better. That did the trick on the air loss.
    Went to MHC KW Dealership in Chattanooga and had them check for Air to Air leak, nothing, turbo was checked out and it was fine.
    Had the overhead done, as I have had the Truck for 110,000 miles now and did not know when it was last done. It showed up 2 injectors were out of adjustment very little, but tech said it was not enough to warrant the 1 mpg drop that it has.
    Put the computer to it and ran for codes, none shown up, checked the mpg out by the computer in truck and it shows 5.49 mpg over the last 106,000 miles??
    I asked the tech how this could show this when it is not getting this, he asked me if someone could be stealing my fuel at night? I told him no I had locking Fuel Caps and park in a well lit area beside my son’s house.
    He told me the only other thing he knew of could be if the fuel lines were starting to collapse, but this usually had a loss of power under a load complaint, which mine doesn’t have.
    This happened once before on the Truck after I got it out of the Body Shop last of July 08, and took it back after getting poor fuel mileage and nothing could be found, did not do overhead, but did put it on the dyno and it straightened itself out the next week.
    Really do not know what to do to try and recover the fuel mileage loss after this?
  12. This ad will disappear if you login
+ Reply to Thread
