+ Reply to Thread
Results 1 to 9 of 9
Thread: Brake Controller
    Trukrswyfe is offline Senior Board Member Trukrswyfe is a trusted source of information and would probably pick up your dry cleaning. Trukrswyfe is a trusted source of information and would probably pick up your dry cleaning.
    Jul 2007
    2,822
    Default Brake Controller
    Ok so it isn't a Trucking question technically.
    But if you all don't mind I 'm going to ask it anyway.
    Have a Chevy S-10 Blazer and husband just got a 19' pull behind camper, it's pretty heavy for the blazer doesn't exceed the manufactor's weight limits. The trail has a different outlet configuration then the standard straight.
    So husband hard wired in an adaptor rather then just plugged in to the outlet.
    Now to my question.
    Has anyone added a brake controller?
    What about the wire that connects the battery system of the trailer to the alternator system of the blazer....... That is something new we haven't used before.
    Suppose to charge the system if the batteries run low.
    He thinks he has it all figured. I just am wondering if anyone here can be help if he needs it.
    Thanks
    TW
  2. #2
    mike3fan's Avatar
    mike3fan is offline Senior Board Member mike3fan is a distinguished poster and probably helps little old ladies across the street. mike3fan is a distinguished poster and probably helps little old ladies across the street. mike3fan is a distinguished poster and probably helps little old ladies across the street.
    Aug 2006
    michigan
    2,740
    I had my controller wired in so I can't answer that but there are thousands of people here that would be happy to answer
    www.rv.net or www.heartlandowners.org
  3. #3
    Jul 2007
    2,822
    Quote Originally Posted by mike3fan View Post
    Thank you Mike.
    Those are perfect.
  4. #4
    Jul 2007
    2,822
    Here ye
    Here ye
    Calling on your electrical knowledge.
    on installing the brake controller under the dash ran in to a hiccup.
    The blue and purple wires we found but when testing for power they only worked when the key was turned. For the braking system to work correctly we need the power of the blue wire to be on without the ignition switch turned on, right?
    Found the correct blue wire under the hood, that has a stead flow of power without key on, so my husband is going to just splice into that wire if no other solution is found.
    Hope that made sense I know how poorly I word things sometimes.
    Thought anyone?
    Thanks again in advance
    TW
  5. #5
    BIG JEEP on 44's is offline Senior Board Member BIG JEEP on 44's is a distinguished poster and probably helps little old ladies across the street. BIG JEEP on 44's is a distinguished poster and probably helps little old ladies across the street. BIG JEEP on 44's is a distinguished poster and probably helps little old ladies across the street.
    Jul 2005
    pod# 110 -Shared with a high risk in a red jumper.
    2,259
    Towing with an S-10 is like 4- wheeing with a Yugo ...Seriously you will be crawling up hills as that little 6cyl catches asthma on every small hill .
  6. #6
    Jul 2005
    2,259
    Quote Originally Posted by Trukrswyfe View Post
    Here ye
    Here ye
    Thought anyone?
    TW
    Why would you need power to the trailer breaks when truck is not running ?...so why would you need a constnt + beyond the acessory switch with ignition key in run or accessory ...The reason the accessory wiring is set that way is to keep from killing your battery when truck is off .
  7. #7
    Jul 2007
    2,822
    Quote Originally Posted by BIG JEEP on 44's View Post
    Thank's Jeep for your lovely metaphor. That may be true, but we have used the blazer for towing our two boats, snowmobiles, utility trailer, and now the camper. So far it is working. The 19' camper comes with power brakes that is why we are adding the controller.
    As for draining the batteries the feature to charge all of them when the engine is running is going to be added so not worried about the batteries going dead.
    I can only explain what my husband explained briefly to me, that for the brakes to work the way he wants them to he wants power to them with or without the key on.
    I didn't know enough to wonder why. He said something about .... oh crap I lost it. sorry in one ear and out the other. . Got the help I was after....
    Thanks Guys!
    TW
  8. #8
    Jul 2005
    2,259
    Thanks Guys!
    TW
    OMG ! even if the truck stalled you would have breaks as long as the key was turned ...LOL
  9. #9
    Jul 2007
    2,822
    Save all your snyde comments for Me,
    I got it all wrong, He said he found a blue wire under the dash and it had power with the key off so he knew it wasn't the trailer wire. He couldn't find the correct blue wire under the dash.
    My mistake not his.
    Say whatever you want about me, Idiot? yes. Ditz? Yes. Strange? Yes.
    Ok sorry....... I am sick.
  10. This ad will disappear if you login
+ Reply to Thread
