My response clearly reflected your suggestion that syn is the "recommended lube" for an internal combustion engine based on Eaton's preference for syn lube in their gear boxes, as typed by you here:
[QUOTE=Copperhead]"""It would take a science lecture, of sorts, to explain all the benefits of a synthetic. Just ask Eaton.... for their extended warranty protection of transmissions and rears, they require a synthetic oil be used. Why not do the same for an engine?""" UNQUOTE
...NOT taken out of context
