Need some advice on where to check for air leak? Have used the spray water and bottle and tried to find the leak (Cannot hear it, but see it on my gauge).
When driving it will go down from 120 to 100 and then the compressor kicks in and brings it back to 120. Idling it will do the same as running. If I leave it overnight then it goes down to 90 to 95 and stops leaking down?
The drop does not change if I am hooked to a trailer or not.
It will drop while driving from 120 to 100 in 5 to 8 minutes, and figured at this rate, I could just crank it up let it idle and find the leak fast, but not happening.
Any advice on where to check?
