+ Reply to Thread
Results 1 to 15 of 15
Thread: Clicking Noise?
    Papa Rick's Avatar
    Papa Rick is offline Board Regular Papa Rick is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Sep 2006
    North Alabama
    476
    Default Clicking Noise?
    My truck 2003 W900L KW, C-15 Cat had started to make a clicking sound sometimes when I go to crank it. I turn the switch off and turn it back on and it fires right up?
    Checked, cleaned and load tested batteries, and all connections, starter, and alternator and all check out fine.
    Called KW Place and explained it to them, and they told me good chance my soleniod on the starter was going bad.
    I asked them if that was hard to change and he told me that it use to be very easy, but now with the newer engines it was almost as easy to just change the starter out.
    Looking for advice and suggestions. He did tell me that my KW has a smaller soleniod in the battery box and it could be that but did not know how to go about checking that, with the exception of when it clicked next time to put a test light on the starter soleniod (not sure about this one) and see if it was getting fire or not, and if not then it was in the battery box.
    Advice and suggestions needed here. Thanks
  2. #2
    Rev.Vassago is offline Guest Board Icon Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name.
    Apr 2006
    The other side of the coin
    9,411
    A clicking noise is almost always the solenoid. We used to hit them with a rubber mallet when the would do that, and sometimes they would grab. I'm not sure about the newer ones though.
  3. #3
    Oct 2006
    Nb
    794
    Default Re: Clicking Noise?
    Quote Originally Posted by Papa Rick
    The battery box solenoid switch; place your test light on the large output terminal and your ground clamp on ground, test light should not glow unless the key is in the CRANK position.
    If you attempt to crank the engine, and it just clicks... 1. the test light glows = solenoid is good, or 2. test light doesn't glow = solenoid is bad... of course, this is the basics; it can get more complicated than this. But, if the test light glows, you're probably looking at a starter
  4. #4
    Papa Rick's Avatar
    Sep 2006
    North Alabama
    476
    Bob, are you talking about the test light on the battery box solenoid or on the starter?
    It does not do this every time or every other time, so could I waith untilit does this and then put the test light to it leaving the switch on when it makes a clicking sound?
    Did they tell me right if it is the starter solenoid it is easier to just buy the whole starter?
    They have my starter on sale this month for $240.00, plus exhange.
    Remember when giving me advice on how to test, my knowledge is very limited on doing this.
    Thanks
  5. #5
    Jumbo's Avatar
    Jumbo is offline Senior Board Member Jumbo is a distinguished poster and probably helps little old ladies across the street. Jumbo is a distinguished poster and probably helps little old ladies across the street. Jumbo is a distinguished poster and probably helps little old ladies across the street. Jumbo is a distinguished poster and probably helps little old ladies across the street.
    Aug 2006
    Northern Wisconsin
    2,102
    Quote Originally Posted by Rev.Vassago
    Why a rubber mallet? Real men use a big hammer or cheater bar.
  6. #6
    pdm
    pdm is offline Member pdm is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Feb 2008
    Ontario, Canada
    83
    The small solenoid in the battery box is probably about 20$, so you may want to think about just replacing it. Delco changed the way the solenoid on the starter is fastened a few years back & it requires the starter to come off to replace it. Used to be able to switch them pretty easy beofre that .
    You can't fix stupid......
  7. #7
    Papa Rick's Avatar
    Sep 2006
    North Alabama
    476
    Checked the Battery Box and found 2 solenoid terminals inside the battery box. They are both corroded over real bad. Will clean them up real good tomorrow and see what happens.
    Thanks for the advice, and will let you know if this stops it.
  8. #8
    NotSteve is offline Senior Board Member NotSteve is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Mar 2007
    935
    I was told if you lick the terminals then drink Coke it cleans them up real good. Not sure I remember the exact sequence so you may want to Google it.
  9. #9
    Orangetxguy is online now Senior Board Member Orangetxguy is well-known and should trademark his/her name. Orangetxguy is well-known and should trademark his/her name. Orangetxguy is well-known and should trademark his/her name. Orangetxguy is well-known and should trademark his/her name. Orangetxguy is well-known and should trademark his/her name. Orangetxguy is well-known and should trademark his/her name.
    Jan 2007
    4,634
    Rick, I have a C-15 in my truck. The starter solenoid went out back in february. Cat in Atalanta did the repair work for me...the solenoid and starter were one piece. The rebuild cost me $587.00.
    Space...............Is disease and danger, wrapped in darkness and silence! Star Trek2009
  10. #10
    Papa Rick's Avatar
    Sep 2006
    North Alabama
    476
    Cleaned the soleniod swith and relay switch inside the battery box, both were corroded real bad. Will post in the next few days if this clears it up, as I believe it will.
  11. #11
    Apr 2006
    9,411
    Quote Originally Posted by Jumbo
    I was pulling a grain wagon, and all I had was a rubber mallet and a sledge hammer. And I couldn't fit the sledge hammer in there.
  12. #12
    Mack2 is offline Senior Board Member Mack2 is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Jan 2007
    North Carolina
    607
    You could have fit the sledge hammer just would have had to relocate a few things.
  13. #13
    Papa Rick's Avatar
    Sep 2006
    North Alabama
    476
    After cleaning them up, it stilled clicked 3 times this week, and once it seemed as if it would not keep turning over after it started turning over to crank.
    Then I was at the KW Place this past week I talked to them and they told me sometimes it was hard to pinpoint the problem unless you start replacing parts (Which can be expensive), they were not trying to sell me parts, but told me that sometimes it is the soleniod in the starter and can be replaced (new one is 60 plus change, or the soleniod in the batter box, it is also 60 plus change.
    They told me that I could even change the starter for 230, but it could not be the starter either.
    I have checked and cleaned all known (That I know of) cables and places, but am looking at advice on this?
  14. #14
    Apr 2006
    9,411
    Suck it up and start changing the solenoids.
  15. #15
    Oct 2006
    Nb
    794
    Typically when the contact disc inside the starter solenoid is worn out... the rest of the starter (drive end bushings, overrunning clutch, etc) are not far behind. If you can change the solenoid yourself - great, if not i would just change out the tired starter.
    To correct a comment made above... the typical H/D starting system uses 2 contact solenoids; one mounted on the starter motor body for engagement carrying the load of the starter current. The second is known as the firewall switch, used to control (or switch) the starter solenoid... the key switch controls this solenoid.
    You are hearing a clicking outside the cab, so this makes me think the key switch is fine. To narrow down beyond that, you would have to use the method i told you in my previous post. The starter solenoid, the firewall switch, the starter motor, or any of the wiring between (least likely) could be bad.
    If the problem cannot be reproduced in the shop, the tech has nothing to measure, and he is "chasing a ghost" until it fails for him in the shop.
  16. This ad will disappear if you login
+ Reply to Thread
