+ Reply to Thread
Results 1 to 10 of 10
Thread: TRANSCRAFT DTL-2000 STEP WILL ONLY RISE WHEN IT SEES WEIGHT
    henboy1 is offline Board Regular henboy1 is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Nov 2006
    324
    Default TRANSCRAFT DTL-2000 STEP WILL ONLY RISE WHEN IT SEES WEIGHT
    This is a 99 step.
    The airbag will only inflate when there is weight on the deck.My 5000ibs personal vehicle did not even make it rise.The previous owner said transcraft stepdecks do that and this was normal.Another rigger said the same thing while others said otherwise.Because of this, the previous owner always kept the red knob(trailer valve) down all the time and only applied the yellow valves when parked(truck).Personally, I don't think this is normal.The bags will only rise after the trailer is loaded and when I drive for about 5-10 miles.Is there a lever under that trailer to look out for?My ABS light is also on (on trailer and no dash ABS light)
  2. #2
    GMAN is offline Administrator Board Icon GMAN is a distinguished poster and probably helps little old ladies across the street. GMAN is a distinguished poster and probably helps little old ladies across the street. GMAN is a distinguished poster and probably helps little old ladies across the street. GMAN is a distinguished poster and probably helps little old ladies across the street.
    Feb 2005
    Tennessee
    15,108
    The air should inflate the air bags whether there is weight on the trailer or not. I assume you are not talking about a trailer that has air bags that will rise so that the axle can be moved? The ABS light should not remain on. You may check to see if you have a switch for a dump valve. It could be on the dash or trailer. I have another trailer that doesn't have ABS. If I hook it to my KW the air bags will deflate unless I switch my air slide for my fifth wheel on the dash. Apparently, the dump valve on that trailer uses the same pin as the ABS on the tractor. If I pull that trailer I have to disconnect the dump valve to keep the air bags inflated. I have a switch on the dash of the other truck for the dump valve.
  3. #3
    Nov 2006
    324
    Quote Originally Posted by GMAN
    I dump my air by the rear ends and I don't have a switch in the dash.I hope there is an adjustment nut for the trailer suspnsion that is used for its' height.
  4. #4
    Orangetxguy is offline Senior Board Member Orangetxguy is well-known and should trademark his/her name. Orangetxguy is well-known and should trademark his/her name. Orangetxguy is well-known and should trademark his/her name. Orangetxguy is well-known and should trademark his/her name. Orangetxguy is well-known and should trademark his/her name. Orangetxguy is well-known and should trademark his/her name.
    Jan 2007
    4,634
    Quote Originally Posted by henboy1
    Check the trailer ride height valve. If it has an electrical wire to it, you need to have the system checked. It might be wired to the trailer electrical connection, and your pig tail makes the suspension dump air.
    You might also just have a bad ride height valve.
    Space...............Is disease and danger, wrapped in darkness and silence! Star Trek2009
  5. #5
    special k is offline Board Regular special k is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Jul 2005
    Ontario Canada
    255
    Do you mean there's no air at all in the bags or just that the bags are still flexible? Check the ride height valve they usually have a rod that is easily disconnected so you can manually raise and lower the suspension if it doesn't change the height then you probably need a new valve. Any good trailer shop can give the measurement for the bag height.
  6. #6
    Nov 2006
    324
    Default I went under the trailer yesterday!
    I went underneath and I couldn't find any leveling device(Iwas between the spread) .This is a step which is quite different from most component location for vans.For ex... my air tank is between the spread while air tanks for vans , I think are further up.What would the adjusting valve look like under the step?O am quite familiar with my air dump valve at my rears. The bags have no air when I am empty and it only rises when it sees weight.No air in the bags are causing my tires to wear.
    When I went underneath, I saw the hoses that goes to the tank and the ABS connection, I will try going under again.
  7. #7
    Nov 2006
    324
    Default I called a dealer.
    I cut down my headache and called an authorized dealer.I gave him the VIn and he said this trailer comes with an AUTO DUMP VALVE.This means there is no manual lever to adjust the ride height.I am sure this part went out.
  8. #8
    Jan 2007
    4,634
    Default Re: I called a dealer.
    Good job! That little sucker is right by the front two tanks.
  9. #9
    Nov 2006
    324
    Quote Originally Posted by Orangetxguy
    As you can see from my previous responses on top I never knew the diference between the "ride height valve" and the "air dump valve".I thought they were all the same because I never had a truck that had the air dump valve in the dash but rather(was never a company driver either) I always pull on the strings on the dryer to drain my tanks or move the lever on my rear end to change the ride height.
    Anyway, I found the "ride height valve" on the trailer and it was quite hidden.
    Viola!fixed my problem.
    Thank you guys!
  10. #10
    Aug 2005
    jackassville (winnipeg, mb)
    3,181
    No problem!
    I love taking all the credit without contributing a damn thing :P
    LOL
  11. This ad will disappear if you login
+ Reply to Thread
