Engine oil and Power Steering fluid are both similar in color, but the two smell differently. Also, P/S fluid has a thinner texture. Either is usually acceptable for your P/S system, but DON'T mix fluids!
...I would doubt very much this shimmy/vibration problem is related to fluid type. Vibration and jerking during static steering might be related to fluid.
Don't suppose you stay under the same trailer all the time and don't grease the 5th wheel every couple weeks? This will cause the jerking you describe but it's usually more noticeable loaded.
| Trucking
Companies | Trucking
Job Search | Online
Job Application | Trucking
Links | Truck Drivers
Message Board | Contact
Us | Site Map
