Results 1 to 6 of 6
Thread: fifth wheel slack
    cowdoc is offline Rookie
    Feb 2008
    44
    Default fifth wheel slack
    OK I'm a relative newbie so please be gentle. 1998 43ft Timpte hopper is the trailer. We've pulled it with 3 different trucks lately and there is slack in the fifth wheel/kingpin on all of them. You can feel it when you take off and sometimes when you change gears. This trailer has 90 inch sides and we load it pretty good. 100K gross and 25-26K tare depending on fuel status. Can the kingpin be built up around the base or what can be done I guess I'm asking. Thanks.
  2. #2
    pdm
    pdm is offline Member
    Feb 2008
    Ontario, Canada
    83
    Most truck/trailer shops will have a king pin guage to check the wear on the pin, & can also check the 5th wheel. You can also leave the trailer brakes on & gently tug against the trailer while watching where its moving.
    You can't fix stupid......
  3. #3
    PhuzzyGnu is offline Board Regular
    Jul 2005
    Planet Houston
    358
    On my Holland fifth wheel you just turn the bolt on the starboard side and it tightens right up. A little turn goes a long way . . .
    I'm not sure why your mechanic couldn't tighten up the fifth wheels a little.
    -p.
  4. #4
    Maniac's Avatar
    Maniac is offline Senior Board Member
    Sep 2004
    Northeast
    963
    No it can't, but it can be replaced though, a lot of welding though, and should definitly be done by a pro welder.
    Kingpins usually don't wear out though, I'd say its the 5th wheel
  5. #5
    Feb 2008
    44
    There is no wedgebolt on this fifth wheel. I'm thinkin 5th wheel needs rebuilding. Kingpin probably worn too. I appreciate the help.
  6. #6
    Oct 2006
    Nb
    794
    Default Re: fifth wheel slack
    Quote Originally Posted by cowdoc
    The obvious is checking the 5th wheel adjust on each unit, and then check kingpin wear with a proper gauge.
    Yes, kingpins can be rebuilt; the pin is built up with weld, and then machined back down to the proper size.
