Hello folks. I apologize if this is the wrong place to be psoting this message, but I can't find a message board related to fire trucks and I have to believe there are some truckers out there with some similar experience to the scenario and system below.
Keep in mind I am trying to solve this problem for a friend over the phone. The truck itself is over 200 miles from me so I may not have all the information needed. here is what I know...
The system...
This truck has a main battery disconnect switch that the firemen turn off when they park the truck in the house and get out. The disconnect switch is a simple heavy duty single pole single throw switch and it is installed on the GROUND side of the system between the frame and the negative battery post.
In addition, there is a charger / inverter installed directly to the battery (does not go through the disconnect) so that when the firemen get out of the truck and disconnect the battery, they also plug in a 110V extension cord. This is extra insurance I guess that the battery will be charged when there is a fire call. This charger / inverter also has a parallel splice that goes directly to a set of 3 power plugs that the firemen use to keep their portable radios charged. This is where the problem comes in...
What's happening is that the little glass fuse that is inside the radio power cord plug keeps blowing everytime they plug the radios in with the battery disconnect switch in the OFF (disconnected) position. If you turn the switch ON (battery connected), you can plug the radios in without blowing the fuse.
Has anybody ever seen anything like this?
