+ Reply to Thread
Results 1 to 13 of 13
Thread: I have some mechanic questions?
    sbatson's Avatar
    sbatson is offline Board Regular sbatson is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Jan 2008
    Florida
    297
    Default I have some mechanic questions?
    I'm driving a 05 century with a 500 detroit and say youre going up a hill or on flat ground and when it coast ( governed at 73) it makes a grinding noise untill you can get on the gas again and it sounds like it is coming from the trany and it only does it when I'm hooked to a trailer loaded or not, any ideas? Also with a trailer loaded or not and I hit a bump, big or small it sounds like it bottoms out in the rear, could it be bags or shocks back there?
  2. #2
    TGTLLC is offline Rookie TGTLLC is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Jan 2008
    46
    i would have the carrier bearing/center support bearing checked out.
    my classic did that and it was the bearing on the drive shaft.
    could also be the bags aren't inflated enough causing a wired drive shaft angle.
  3. #3
    sbatson's Avatar
    Jan 2008
    Florida
    297
    That might be right because like I said it bottoms out in the back like something is bad so bags being weak probably could cause something else down the line, makes sense to me.
  4. #4
    TomB985 is offline Board Regular TomB985 is a trusted source of information and would probably pick up your dry cleaning. TomB985 is a trusted source of information and would probably pick up your dry cleaning.
    Sep 2006
    Columbus, OH
    463
    Sounds like your suspension ride height is too low...I remember the mechanics telling me that if they set it too low, it will change the driveline angle too much, and it will cause all kinds of problems in the driveline...as well as bottom out...
  5. #5
    Windwalker is offline Board Icon Windwalker is a distinguished poster and probably helps little old ladies across the street. Windwalker is a distinguished poster and probably helps little old ladies across the street. Windwalker is a distinguished poster and probably helps little old ladies across the street. Windwalker is a distinguished poster and probably helps little old ladies across the street.
    Oct 2005
    Been there and gone...
    6,187
    Quote Originally Posted by TomB985
    Use a tape-rule, and measure the height of the frame on other tractors and then measure yours. If you have a problem with the height, you'll notice the difference in height.
    Destroy the cities...
    and they will rebuild them.
    Destroy the farms...
    The bill has come due.
  6. #6
    Kranky's Avatar
    Jun 2006
    Wisconsin
    1,108
    Best way to check ride height is to obtain the manufacturers specifications for the type of air ride on that particular truck.
    The service manual will outline the proper dimensions and exactly where it is to be measured.
    Improper ride height is not caused by "the bags being weak", it is caused by the ride height control valve or linkage rod being out of adjustment, defective, or broken.
    Air ride when working properly will maintain a constant ride height whether the truck is empty or fully loaded, unless the truck is so grossly overloaded that full reservoir pressure (120 lbs.) applied to the bags cannot support the weight.
  7. #7
    Jan 2008
    46
    for freightliner classic`s and fld`s lift is supposed to be 3 and 1/2 inches if i remember correctly. not 100% positive for other makes but might be a starting point to look at if your manual doeset tell you,
  8. #8
    Doghouse is offline Senior Board Member Doghouse is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Mar 2007
    1,010
    Quote Originally Posted by Splitshifter
    Absolutley right on the money Split.
    The guys put in 2 trannies before I,...repeat I figured out they had the ride height set wrong.
  9. #9
    sbatson's Avatar
    Jan 2008
    Florida
    297
    Well I talked to the office today and they said they checked the bags and they are good, but said I had the tandems all the way back on the trailer, well ya I did so my load would weigh out but it does it no matter heavy or not, so I told them about the ride height and carrier bearing so we will see what happens.
  10. #10
    Mar 2007
    1,010
    So what if you had the trailer tandems all the way back. If you were legan on the tractor,...why would this make any diff?
    Are they pullin' your leg?
  11. #11
    sbatson's Avatar
    Jan 2008
    Florida
    297
    Thats what I said , I told my manager I had to put in the back to get the load to weigh and I know it will ride like crap that way but that dont explain the bottoming out in the back and the grinding noise under the trany.
  12. #12
    sbatson's Avatar
    Jan 2008
    Florida
    297
    Well I forgot to report on here what my problem was, it was the self leveler for the rear susp., replaced it, amazing it was like new no problems since then.
  13. #13
    heavyhaulerss's Avatar
    Jan 2007
    north alabama
    1,186
    thats the same as air bag prob. lol. i adjusted mine the other day & adjusted the rear bags too low & it made a grinding noise. pulled over & adjusted the adjusting rod to rais bags & noise went away. your bag must have been bottoming out. the leveling sys prob let the air out but would not activate to put air in. anyway. glad you got it fixed & glad you posted what the prob was.
  14. This ad will disappear if you login
+ Reply to Thread
