+ Reply to Thread
Results 1 to 4 of 4
Thread: Isolated battery
    Malaki86's Avatar
    Malaki86 is offline Senior Board Member Malaki86 is a trusted source of information and would probably pick up your dry cleaning. Malaki86 is a trusted source of information and would probably pick up your dry cleaning. Malaki86 is a trusted source of information and would probably pick up your dry cleaning.
    Aug 2004
    West Virginia
    3,878
    Default Isolated battery
    After having an almost dead set of batteries two times in the past two days, I need to figure this out.
    First off, I'm in a company truck. I've talked to our shop foreman about adding an isolated battery and he's fine with it. They'll even install everything for me, I just have to provide the materials.
    I have a 1,500 watt inverter that's hooked to my trucks batteries (4 batteries). The inverter only runs my laptop when the truck is shut down. If I need to use the microwave, I start the truck.
    The only other thing that runs constant is my cooler. It's a 12-pack sized Rubbermaid.
    I noticed that if I shut off the cooler when I'm shut down, the batteries do fine the next morning.
    Anyway, what I want to do is to add one or two deep cycle batteries that the truck will charge, hook the inverter and cooler directly to them. What I was thinking would be to add a battery isolator, such as this one:
    http://www.jcwhitney.com/2-BATTERY-S...0926_10101.jcw
    The question is, how would this be wired to the truck? It has 3 posts, which I know what they are - battery 1, battery 2 and alternator. So, how would that work in the truck?
    Any ideas?
    Wanna play a couple online games that are absolutely free? These are the games I play on a very regular basis:
    Battle of the West & Mobs Law
  2. #2
    Aug 2005
    jackassville (winnipeg, mb)
    3,181
    Sounds like you just need new batteries, have the current ones load tested.
  3. #3
    Doghouse is offline Senior Board Member Doghouse is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Mar 2007
    1,010
    That cooler shouldn't be running your batteries down like that. Allan is right replace them and you'll be fine.
  4. #4
    Rawlco is offline Senior Board Member Rawlco is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Jan 2006
    Central Maine
    1,194
    If they will install it then the question of how the wiring goes isn't your problem exactly.
    I guess I would interpret those three points on the isolator you linked to as:
    1) Starting Battery(ies) positive
    2) Isolated battery(ies) positive
    3) Alternator positive
    The Road goes ever on and on
    And I must follow, if I can,
    Pursuing it with eager feet,
    -- J R R Tolkien
+ Reply to Thread
