The CC worked perfectly for my first 30,000 miles. I had a new tranny put in, and my CC problems began. My speedo is now 2mph off. The CC never worked right again, and quit working all together 50 miles down the road from the trans shop.
I would have gone back, but this shop was so bad,...I decided to try and fix it myself.
I have put in a new sending unit, and the CC worked perfectly for 1,300 miles. Then it started acting up again:
1.Shutting off while under a load pulling a small hill.
Now it's back to shutting off 10 seconds after I turn it on, but only while I'm under a load, when I'm empty it shuts off with no pattern even on flat roads, or it works for hours at a time with no problems.
1995 International 9400 with a DD 60/Eaton 10 speed
Any ideas??
