+ Reply to Thread
Results 1 to 5 of 5
Thread: More starting problems
    Aug 2005
    jackassville (winnipeg, mb)
    3,181
    Default More starting problems
    I've already changed the starter relay. The wiring is all good. The solenoid gets power.
    But it won't turn over unless you use a screwdriver from + to the solenoid. When I did that, the screwdriver melted really bad.
    Is it possible the solenoid has a short in one spot, but it rarely stops on that part?
    I noticed also whenever it would be "dead" the relay clicks really loud... as if whatever it's supplying is shorted. I think the relay doesn't have enough juice to get the solenoid off of the shorted spot. But the screwdriver has enough juice to get it kicked off.
    So.. do I have a shorted starter solenoid? It's only ~3 years old.
  2. #2
    Aug 2005
    3,181
    I'm thinking now the solenoid is "sticky" in one spot. I've always noticed that it makes a huge clunk whenever it engages. Even brand new (4 years old or so).
  3. #3
    pdm
    pdm is offline Member pdm is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Feb 2008
    Ontario, Canada
    83
    when the starter engages a contact disc in the solenoid connects the 2 larger posts on the solenoid, sounds like its getting arced & burned a bit.
    kenworth usually has pretty good pricing in genuine delco starters....
    You can't fix stupid......
  4. #4
    Aug 2005
    3,181
    Not interested in delco starters, this one only lasted 3-4 years. I'll be looking at denso.
  5. #5
    Aug 2005
    3,181
    Well I'm going to try out a delco 39mt... they're supposed to have much better solenoids then the 42mt's. Gear reduction as well.
+ Reply to Thread
