+ Reply to Thread
Results 1 to 6 of 6
Thread: Oil overage
    vontrial is offline Member vontrial is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Aug 2006
    MS
    121
    Default Oil overage
    Had my oil changed Friday, and company overfill by 1 gallon did not noticed til I left and on the rd ,do I need to drain it out. Det. engine, 10 galllons of oil and 1 gal on Lucas,
    Thx in Advance
  2. #2
    Oct 2006
    Nb
    794
    Default Re: Oil overage
    Quote Originally Posted by vontrial
    Thx in Advance
    I would just drain the lucas out... and then leave whatever's left
  3. #3
    Kranky's Avatar
    Jun 2006
    Wisconsin
    1,108
    Quote Originally Posted by bob h
    Thx in Advance
    I agree.
  4. #4
    Dejanh is offline BANNED Senior Board Member Dejanh has a checkered past and should take up chess.
    Nov 2006
    807
    Always tell whoever is changing your oil to fill it up between the lines, not all the way to the top.
    they measure oil level right after you shut that engine down, which is wrong because not all oil is settled down the way it is suppose too.
    My oil pan gasket leaked out because of it as that extra oil has to come out somewhere eventually.
  5. #5
    duck is offline Member duck is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Sep 2006
    Green Bay - Wisconsin
    128
    Usually what a place does is fill by known quantity - not pulling the dipstick and checking. C15 40 quarts, ISX 48 (2008 engine 44) etc. They probably didn't account for the Lucas but like others said - drain the Lucas and run the rest.......
    Andrew
  6. #6
    Musicman's Avatar
    Musicman is offline Senior Board Member Musicman is on the right path.  You could probably safely loan them a quarter.
    Dec 2005
    Way Way Way Down South in IL
    648
    Are you sure your dipstick reads correctly? I dunno about Detroits, but my former CAT manual basically said not to trust the dipstick innitially. Change the oil, fill with the proper quantity, run the engine for a minute or so, let settle for a few minutes, then check the dipstick. Whereever the oil level is at that time is is where you should engrave or mark your new full line. My '06 ISX always reads well past the full mark after an oil change. Each shop is not overfilling the oil, rather the dipstick is off.
