Both of my overhead sleeper lights stopped working at the same time the other day, bulbs are good. The chart for my fuse panel is gone, so what fuse is it for these? Or is it inline somewhere? Thanks.
dumb
Maybe you should have a seat. :twisted:
lol
my apologizes for hijacking your thread an filling it with
chit wont happen again.
delete
It's a legit question, I get all the fame and attention I need on another website. I'm just tired of not being able to see at night. The stupid maplights are no help at all.
Originally Posted by ChrisHansen
check all of the fuses, the one that is blown is the one that supplies the lights..
Did that last night. No luck.Originally Posted by Fredog
If it is a fluorescent type, it is probably the starter. On my Pete I had to replace the entire light assembly due to this.
Regular incandescent bulbs.
anybody else got a guess?
If the fuse or circuit breaker is not blown and the bulbs are good, then it has to be a bad switch, bad ground, broken wire or bad connection somewhere in that circuit.Originally Posted by ChrisHansen
I'm not a Freightliner guru, so I can't get more specific, but that was a list of causes that would be applicable to that general type of problem.
They're not flourescent? All my Freightshakers are...
This hasn't been mentioned yet, but there are two panels for these trucks. I lost all the power to the DC outlets and searched a LONG time before finding the panel behind the sleeper curtain on the drivers side of the truck.
You may have already found it and eliminate it as a problem.. but thought that I'd suggest that.
| Trucking
Companies | Trucking
Job Search | Online
Job Application | Trucking
Links | Truck Drivers
Message Board | Contact
Us | Site Map
