You guys were a BIG help with the last problem i had. Hope you can do it again.
Engine tends to run warm even during cold weather. Takes it a while but the temps edge up until it ingages the fan. Cools off good and then repeats. Sometime is even shoots down like it got a burst of water from somewhere. Almost like a thermostat opened. Had the thermostats replace when i had the last problem fixed that you helped with (oil comsumption). Need to get this thing repaird before HOT weather gets here. I have also power washed the radiator to make sure nothing was trapped in the cooling fins.
