Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
Thread: More help
  1. #21
    Blind Driver's Avatar
    Blind Driver is offline Senior Board Member
    Apr 2006
    New Albany, IN
    540
    Quote Originally Posted by Ronm
    It is not the fan. It comes on as the engine temps rise like it should. I will check the hose and clean all the cooling equipment on the front of the engine. Soon as it gets warm enough. Thanks so much for all the help. Like i said before. Keep the info flowing.
    Be sure to wash from the engine side out to the front. Or you may just push the junk deeper into the radiator. Also use a good citric based degreaser. It'll dissolve the road grime.
    I have seem some water pump vanes wear out and drive mechanics nuts. But that would be the last thing at 150k miles that it should be.
  2. #22
    Ronm is offline Rookie
    Dec 2007
    Gates, North Carolina
    33
    I took the A/C cond. cooler off and washed from the engine side out. I sprayed both CAC and the radiator with a good degreaser before washing. Looked like there was enough room between the CAC and the radiator for debris to fall out the bottom. I am also going to change the radiator cap. We have a race in Farmington, NC next weekend will see how it does then.
    I deserve respect for the things I DO NOT DO.
  3. #23
    Dec 2007
    33
    Well, took the truck out on a trip this weekend. After cleaning the cooler and radiator with a water nozzle and water hose from the engine side the temps are still coming up. Runs up to 205, the fan comes on and the temps go back down. The cycle starts all over again. Could the radiator cap cause this? Gotta get this thing fixed before summer gets here or i am in deep trouble. Thanks for any help guys. Would have been better off to use a power washer instead of just house water preasure? Thanks for the help guys.
  4. #24
    pdm
    pdm is offline Member
    Feb 2008
    Ontario, Canada
    83
    Ild be surprised if a rad cap would fix this but it certainly is worth a shot. Is it still gtting warm?
    You can't fix stupid......
  5. #25
    heavyhaulerss's Avatar
    Jan 2007
    north alabama
    1,189
    check water tank & all water line. make sure there ar no restrictions anywhere. if non are obstructed my bet would be the water pump gear or vanes
  6. #26
    Kranky's Avatar
    Kranky is offline Senior Board Member
    Jun 2006
    Wisconsin
    1,108
    If you use a pressure washer to clean the radiator or CAC, be careful to only spray straight through the core, otherwise if you spray at an angle the pressure can knock the fins over sideways, resulting in no airflow at all in the affected area.
    BTW, the late model Cat engines in the fleet where I work (C12, C13 & C15) run up to 210, then the fan comes on and the temp drops to 180. Lather rinse & repeat all day long.
    I thought that was abnormal so I consulted the Cat literature regarding those engines and that is indeed the proper operating parameters.
    I would suggest you access the factory info for your particular engine and compare it to the temp readings you're experiencing.
  7. #27
    2hellandback is offline Member
    Dec 2007
    Idaho
    89
    I would put money on the water pump weak or starting to go ! :sad:
    Belts look ok?
    Hoses old, collapsing or kinking?, unraveling inside slowing flow?
    I'm not familiar with your engine so I'm just throwing things out there!
    You said it was a Cat,,, fur balls plugging the radiator?
    Sorry just couldn't resist that !
  8. #28
    Dec 2007
    33
    Quote Originally Posted by 2hellandback
    Belts look ok?
    Nope, furr balls was the first thing i checked.
    Come to find out it was the belt. It had one bad spot in it. It seems that when it got to the bad spot it would stop turning the pump. Everytime i looked at the belt it seemed fine. Bad spot would always be in the pulley where i could not see it. Great call on the belt. I was getting ready to put a new pump in it.
  9. #29
    Bobby's Avatar
    Bobby is offline Member
    Apr 2006
    Ca.
    165
    The belt had a bad spot were it wouldn't turn the pump ??
  10. #30
    Dec 2007
    33
    That is correct. Not sure why it did not burn off but it did not. I changed the belt and the problem has gone away. Took it for a test drive withoutthe trailer and it worked great. Took everyting out on the road last weekend and everything is just fine again. One thing i can say abt. this problem. With all the suggestions and all the things that i tried i have learned a lot. Thanks to all who helped. Your suggestions and comments are greatly appreciated. Thanks a bunch guys.
  11. #31
    Bigmon is offline Senior Board Member
    Jan 2006
    North East
    1,094
    Quote Originally Posted by enobeenob
    It could be a head gasket starting to go bad, check the outside of the engine block for dried coolant leaking from the sides of the head drying up on the engine block. ?
    I have a Series 60 that I noticed a little dried coolant on the front right side of the block. It was about 1/8" wide and a couple inches long. Detroit guy on the phone said it's most likely a loose clamp or hose, but can't tell until he see's it. If it is a head gasket how long do you think it will last?
  12. #32
    duck is offline Member
    Sep 2006
    Green Bay - Wisconsin
    128
    No one can say for certain how long something will last like that. Find a shop with either a dyno or someone well versed in the 60 series.
    Andrew
  13. This ad will disappear if you login
