+ Reply to Thread
Results 1 to 6 of 6
Thread: Instument Problem
    Oct 2007
    23
    Default Instument Problem
    Hey Guys, 8)
    I just finished my first month as a O/O, and it went pretty good except that when I drive through snow or rain my instruments ( speedometer, odometer, oil pressure, boost pressure Ect.) would go out.. :sad:
    If I stopped amd let the truck dry out it would be fine. But later in the trip it was ovious that the problem was getting worse
    I have a 2002 Volvo 660 with a Detriot 60 Series w/Eaton Autoshift Trans
    Any Ideas?? :? :? :?
  2. #2
    enobeenob is offline Member enobeenob is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Dec 2007
    117
    Default Re: Instument Problem
    Quote Originally Posted by C and R Trucking
    Hey Guys, 8)
    It could be a bad ground wire or water is getting into the wiring somewhere. I suggest crawl underneath your truck and check for loose connections and maybe see where water could get pooled up and the drain is clogged.
  3. #3
    Oct 2007
    23
    Thanks for the advise
    Ive been under the truck for a hour today and I couldn't find anything loose
    I guess it's time to take it to the Volvo dealership
  4. #4
    Dec 2007
    117
    Check by the base of your windshield, you could be geeting water in there when it rains and the water is getting into your dashboard.
    Take the two torx screws off on top of your instrument cluster and pull the cluster towards you, check the inside of the cluster for water or moisture seepage.
  5. #5
    CaliTrucker's Avatar
    CaliTrucker is online now Board Regular CaliTrucker is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Apr 2006
    Auburn, CA
    222
    Definitely sounds like water got into somewhere it shouldn't be.
    This happened to the dump truck i drive and after our shop guy did a little investigating there was a relay, i believe, that was full of water. So he replaced the part and its good as new, well as good as an almost 20 year old dump truck can be.
  6. #6
    Dec 2007
    117
    Any update on your problem?
+ Reply to Thread
