+ Reply to Thread
Results 1 to 4 of 4
Thread: Where to put oil
    grainhauler08 is offline Rookie grainhauler08 is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Jan 2008
    Akron,Iowa
    18
    Default Where to put oil
    Okay my front driver is leaking a little oil from driveshaft seal,where do you add oill at,this is on a 2001 IH 9400.This axle was rebuilt not to long ago,before I purchased it,its seeping. What kinda oil goes in the axle?Also what something like this cost to have seal replaced?
  2. #2
    Rev.Vassago is offline Guest Board Icon Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name.
    Apr 2006
    The other side of the coin
    9,411
    Replacing seals isn't that expensive. If it's already leaking, it's time to get it in. Waiting is only risking more problems. Just the cleanup from a blown seal will hurt your pocketbook, as the oil usually coats the brakes pretty good.
    As far as where to add oil, I believe those hubs are a sealed system (although I could be wrong), in which case you can't add oil like you can to a trailer hub.
  3. #3
    Kranky's Avatar
    Jun 2006
    Wisconsin
    1,108
    Default Re: Where to put oil
    Quote Originally Posted by grainhauler08
    Check the vent on top of the axle housing. A clogged vent can allow pressure to build up inside the housing and cause an otherwise good seal to leak.
    To add oil, use the plug on the rear side of the axle housing (it's located about halfway between the bottom and top). Some have a square headed pipe plug, and some have a plug with a recessed square drive which you can use a 1/2 inch drive breaker bar to loosen.
    Remove the plug and fill the housing so the lube is up to the filler hole.
    Most rears today use 75W90 synthetic gear lube.
    After you've filled it, replace the plug and tighten it.
    (and BTW, get the seal fixed ASAP).
    A blown seal on the driveshaft yoke will spray gear lube all over the underside of the truck, which is messy, and an invitation for a closer look in the event of a DOT inspection.
  4. #4
    Apr 2006
    9,411
    Apparently I am confused. I thought he was talking about an axle hub. My bad.
+ Reply to Thread
