+ Reply to Thread
Results 1 to 5 of 5
Thread: truck won't start
    KAIMIKAZEE is offline Member KAIMIKAZEE is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Sep 2005
    135
    Default truck won't start
    my truck started fine this morning, but after it warmed up...there seems to be a buzzing noise coming from the firewall...
    my lights would dim when the the buzz would go on...
    i stop the ignition and coudn't start the truck anymore...
    funny thing is when i take the keys out...and press on the engine start button my dash lights would go on...
    i here a clicking noise and it's coming from a relay that's mounted right onto the firewall by the engine, it has 4-5 wires connected to it. could that be the "starter relay"???
    i know it's not the starter just changed it last summer...anyone experienced a faulty ignition switch or ignition solenoid???
    oops almost forgot it's a '97 pete 379 with a 3406e...
  2. #2
    Fredog is offline Senior Board Member Fredog is a trusted source of information and would probably pick up your dry cleaning. Fredog is a trusted source of information and would probably pick up your dry cleaning.
    Apr 2005
    North Georgia
    3,665
    Default Re: truck won't start
    Quote Originally Posted by KAIMIKAZEE
    yes that is the starter relay, sometimes it gets stuck in a dead spot. usually a light tap will get it going, if it continually does it, replace it
  3. #3
    Blind Driver's Avatar
    Blind Driver is offline Senior Board Member Blind Driver is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Apr 2006
    New Albany, IN
    540
    Take something like a screwdriver and touck the two big posts together. It'll send current directly to the starter. Don't make too many sparks :wink:
  4. #4
    Sep 2005
    135
    well changed the old relay on the firewall and nothing happend...
    decided to change the starter and the truck started...
    wonder what could've caused the solenoid on the starter to short...
    the connections was all gunky and dirty wonder if that was the cause...
    thanks for the help anyways...
  5. #5
    Aug 2005
    jackassville (winnipeg, mb)
    3,181
    They just wear out.
+ Reply to Thread
