+ Reply to Thread
Results 1 to 10 of 10
Thread: MOTORKOTE
    marcel27208's Avatar
    marcel27208 is offline Senior Board Member marcel27208 is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Aug 2006
    salisbury,NC
    1,049
    Default MOTORKOTE
    has anyone ever used this product(motorkote)......... its about 70 bucks a gallon, i seen it at a steel city truck stop somewhere in indiana.........
    yeah im back
  2. #2
    Aug 2005
    jackassville (winnipeg, mb)
    3,181
    junk
    don't bother
    Chlorinated parraffin. In other words, it breaks down under normal engine operating temps and can be harmful to your engine.
  3. #3
    enobeenob is offline Member enobeenob is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Dec 2007
    117
    snake oil
  4. #4
    Copperhead's Avatar
    Copperhead is offline Board Regular Copperhead is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Oct 2007
    Kellogg, IA
    374
    I agree.... not worth the money.
    Look... motor oils today are pretty darn good, especially the higher end synthetics. Stick with them, do good oil analysis and pms and you will keep cost effective and get good protection.
    See the discussions on the forums and the testing that has been done at www.bobistheoilguy.com
    Most addtives are not worth the money and may actually cause a problem.
  5. #5
    adamikey is offline Rookie adamikey is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Feb 2009
    2
    I own a small trucking co. and have been using motorkote in all my trucks for 6 years. Three of my n-14’s have over 1 mil. miles on them and the rods & maines were replaced at 900 thousand miles.
    I had a driver climbing westbound out of Albuquerque in the summer when he lost his turbo. In all of his wisdom the driver decided to restart the engine at which time the engine started to use the oil as fuel and the engine did not stop running till all the oil was depleted. Long story short the only damage to the engine was a new turbo and charge air cooler this was two years ago the engine is fine. I swear by MotorKote!!!!
    It is also cheaper to run than lucas. 30$ per every four oilchanges. I also run it in the Trans.,Diffs.,and Steering.
  6. #6
    solo379's Avatar
    solo379 is online now Senior Board Member solo379 is on the right path.  You could probably safely loan them a quarter.
    Feb 2004
    3,611
    Thumbs down
    Sounds like commercial...
  7. #7
    Aug 2006
    salisbury,NC
    1,049
    when i seen post i was about to say i asked about that stuff about a year ago................1 positive response....a year later
  8. #8
    Copperhead's Avatar
    Oct 2007
    Kellogg, IA
    374
    Having high miles on an engine is not a valid endorsement of MotorKote. I put 1.4 millions miles on a previous N-14 and NEVER had the rods or mains done in that time, never lost a turbo or had anything more than injectors replaced. I only used Kendall 15w40 oil and Baldwin filters. It still was not using any more than 1 gallon every 10K miles and getting near 7 mpg when I got out of it. It wasn't my truck, or else I would have kept it.
    The oil producers have put a lot of research into the additive packages they put in their oils. I am pretty sure that the over the counter oil additives are totally unnecessary. In fact, some of these additives will conflict with the additive package in some oils and do more harm than good. Why bother? If you are wanting to spend money on something, then spend it on oil analysis kits from a reputable lab and sample your oil and see how it is doing and how your engine is holding up. You will get more bang for your buck doing that.
  9. #9
    Kranky's Avatar
    Jun 2006
    Wisconsin
    1,108
    Quote Originally Posted by Copperhead View Post
    X2
  10. #10
    Maniac's Avatar
    Maniac is offline Senior Board Member Maniac is on the right path.  You could probably safely loan them a quarter.
    Sep 2004
    Northeast
    956
    Oil additives...........snake oil
    Read it here
    Car maintenance bibles: Oil Additives
    If you really feel the need to use some additive send ME whatever $$$ you think its worth and I'll send you a bottle of something you can put in.
  11. This ad will disappear if you login
+ Reply to Thread
