Results 1 to 13 of 13
Thread: brakes
    Jul 2007
    41
    Default brakes
    do you adjust trailer brakes at the same time when you do the truck
    THANK YOU
  2. #2
    roadranger is offline Board Regular
    Sep 2005
    Junction of MA CT RI (Putnam CT)
    246
    You "check" them, you don't "adjust" them - unless it is a very old trailer or tractor with manual adjusters. Automatic adjusters have been standard since 1990 or so? If an automatic adjuster is out-of-adjustment it needs to be rebuilt or replaced - "adjusting" it is just masking the real problem and it will probably be out again in a couple days (or hours!) ...
  3. #3
    CaptCaveman is offline Rookie
    Aug 2007
    Amarillo TX
    15
    You can adjust automatic slack adjusters but its a pointless exercise unless the adjuster isn't working or DOT is running a safety blitz and you want to make sure your brakes are "snug".
    The battle may not always go to the strong nor the race to the swift but thats the way to bet
  4. #4
    Kranky's Avatar
    Kranky is offline Senior Board Member
    Jun 2006
    Wisconsin
    1,108
    Where I work, whenever I have a truck in for PM, I'll manually adjust the brakes just to be sure that they're within spec.
    And if I find one that is "way out" of adjustment, then the auto slack gets replaced.
  5. #5
    Mackmechanic is offline Member
    Aug 2007
    Spiro, Oklahoma
    52
    Quote Originally Posted by Splitshifter
    Exactly
    We have to check and adjust the slacks, manual or not
    Of course, the way vocational trucks run through brakes, it probably isnt a bad thing lol
  6. #6
    Aug 2005
    jackassville (winnipeg, mb)
    3,189
    Checking and adjusting are two totally different things.
    If you have automatic slacks, and you check them and they're not adjusting correctly, they get tossed.
    You do NOT adjust auto slacks. If they're out of spec, there's something wrong with the system and they need to be REPLACED.
  7. #7
    Not sure if this is correct but this is what I was told.
    Get on a hill and roll backwards tapping the brakes to cause the trailer slack adjusters to adjust.
    Step on the brake up to 90 psi application to cause the truck slack adjusters to adjust.
    Is this correct?
  8. #8
    Kranky's Avatar
    Jun 2006
    Wisconsin
    1,108
    Quote Originally Posted by allan5oh
    Evidently you missed the second sentence in my post Allan:
    :wink:
  9. #9
    Kranky's Avatar
    Jun 2006
    Wisconsin
    1,108
    Quote Originally Posted by SteveBooth
    Is this correct?
    Auto slacks adjust as necessary when the brakes are applied and released.
    It makes no difference whether the truck or trailer is stationary or moving forward or backward.
    The brake application in reverse thing is for 4 wheelers.
  10. #10
    Aug 2005
    3,189
    :wink:
    Your second sentence is irrelevant, because even if it is a "bit out" it should still be replaced, and the slack should NOT be adjusted.
  11. #11
    Oct 2006
    Nb
    794
    Quote Originally Posted by CaptCaveman
    brakes don't need to be snug... they need to be in spec
    many slack adjuster manufacturers (excluding a-m) recommend NOT adjusting auto slacks as it wears out the clutch mechanism
  12. #12
    Oct 2006
    Nb
    794
    an overstroked pushrod should lead you to the same conclusion without touching a wrench...
  13. #13
    Sep 2005
    246
    In any case - if you adjust or repair brakes without being certified and that truck gets in an accident you're in a heap of you-know-what. The certification class is usually only one day and will teach you how to measure the stroke properly AND will teach you that it is NOT legal to adjust any brake adjuster without measuring the stroke afterwards and that it is NOT legal to adjust an automatic adjuster unless it has just been replaced or it had to be loosened to replace or work on something else!
  14. This ad will disappear if you login
