Results 1 to 4 of 4
Thread: Air Bags
    sodbuster is offline Member
    Aug 2007
    East Texas
    65
    Default Air Bags
    I have a kw t800 with 8 air bags, and gauges to monitor the pressure on the left and right side. I have noticed that the right side always has about 30 psi more air than the left side. I have measured the height of the rear frame rails and they seem to be the same height. I don’t like seeing the right side having 80 psi on the bags and the left only having 50 psi. Is this something I should address. Also when I am unloaded the left bags have no air and the right side has 30 psi.
  2. #2
    Jul 2007
    41
    sounds like the gauge might be bad
    THANK YOU
  3. #3
    Part Time Dweller's Avatar
    Part Time Dweller is offline Board Regular
    Jan 2007
    Western Chicago Suburb, IL
    442
    Some KW 8 bag has right and left leveling valves. I would look into replacing them. Sounds like the left valve is bad.
  4. #4
    Oct 2006
    Nb
    794
    Default Re: Air Bags
    Quote Originally Posted by sodbuster
    i agree with ptd, it has a levelling valve on each side of the chassis... replace both
    the gauges are easy enough to check with regulated shop air
