Results 1 to 6 of 6
Thread: More drum questions
    RostyC is offline Senior Board Member
    Oct 2005
    2,278
    Default More drum questions
    I have the old style drums (centrifuge?)that need to be replaced at a cost of 290.00 per drum, drum only not install. Is there a way to switch to a steel drum which cost a lot less?
  2. #2
    Aug 2005
    jackassville (winnipeg, mb)
    3,189
    Yes.
    You might have to change studs.
    I didn't.
  3. #3
    Part Time Dweller's Avatar
    Part Time Dweller is offline Board Regular
    Jan 2007
    Western Chicago Suburb, IL
    442
    Centrifuse drums are not "old style".
    They are a light weight, albeit expensive alternative to cast drums. You are looking at about 60lbs per drum difference in weight. Centrifuse drums are fabricated from sheet steel onto which molten iron is applied in a centrifuge process.
    The two style drums are completely interchangeable, with no need for stud change, so unless you need the weight savings, go for the cast and spend the $$ you save on something else.
  4. #4
    Oct 2005
    2,278
    Thanks guys
    Thanks for the explanation PTD.
    I went to another parts store on Friday and they said to bring them my drum number and they'll give me some options.
    Somebody else I was talking to said 180.00 is more reasonable for a centrifuge drum.
    I'll let you know how it turns out.
  5. #5
    Aug 2005
    3,189
    Quote Originally Posted by Part Time Dweller
    Incorrect, some trucks will need new studs in the hubs, because the cast drums are thicker, you may not have enough thread engagement with the wheel nuts.
    Mine was fine, from what I hear I got lucky.
  6. #6
    Jan 2007
    442
    Well.........I must be "lucky" also, I have changed out several trucks over the years and never had to change the studs either. Maybe I should buy some lottery tickets, eh ?
    I highly doubt the manufacturers are going to have not only different length studs for aluminum or steel wheels, and different lengths for cast or centrifuse drums. That would be like 4 different combinations. Sheesh, you ever heard of standardization?
