Results 1 to 6 of 6
Thread: fifth wheel and kingpin
    sodbuster is offline Member
    Aug 2007
    East Texas
    65
    Default fifth wheel and kingpin
    When pulling away from a stop I sometimes fill a slight secondary pull after the clutch is released, I only notice this when loaded and strating out in the lower gears, it does not always happen, I was wondering if there is ware on the trailer kingpin if this could be what I feel. Or maybe u-joints or other driveline problems. Thanks for any comments.
  2. #2
    Doghouse is offline Senior Board Member
    Mar 2007
    1,010
    Set your trailer brakes and give it a good back and pull forward with somebody watching.
  3. #3
    silvan's Avatar
    silvan is offline Senior Board Member
    Mar 2006
    East Coast
    856
    Default Re: fifth wheel and kingpin
    Quote Originally Posted by sodbuster
    Pay attention for the feeling of the trailer lagging behind the trailer a little. You pull out, then a fraction of a moment later, you feel a whump. Let out of the fuel to coast between gears, whump, catch the next gear and accelerate, whump. That's what a 5th wheel that's slap worn out feels like. Kingpin problems are less likely, though I've heard of kingpins on tankers getting whittled down to nothing by all the surge action.
  4. #4
    Blind Driver's Avatar
    Blind Driver is offline Senior Board Member
    Apr 2006
    New Albany, IN
    540
    Check the 5th wheel bushings. Normally I would use a kingpin welded to a shaft. Then the pin in is locked in the 5th wheel, and then the shaft is used to lift the 5th wheel up to see if the bushings have any wear in them.
  5. #5
    Aug 2007
    East Texas
    65
    thanks for the info
  6. #6
    The 5th wheel has teeth and can be adjusted a few times and tightened up. If there is no more room to tighten it, then it must be rebuilt.
    I had this done once when I started and it's cheap.
