Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
Thread: Dumb Rookie Question
  1. #21
    Jackrabbit379 is offline Board Icon
    Oct 2005
    Wichita Falls,Tx
    7,100
    Quote Originally Posted by yoopr
    In the old days we had a knob that you pulled out and then the knob turned to get the idle up to where you wanted it
    They dont even have throttle cables anymore. Now they have electronic motors, so they have toggle switches that you tap, and it bumps up the throttle. Just crazy.
    You remember when the Truck stops sold that gizmo that attached to the Steering wheel(I think it went to the steering wheel) and had a rod with a tip that went to your Pedal and you set the Idle by adjusting a Nut? :P
    We have a couple of them. Or, the outfit that I do part time farm work for. They have 2 R Model Macks, and we keep those rods in the floorboad. We use them in the winter when we first crank up the trucks.
  2. #22
    Mackman is offline Senior Board Member
    Sep 2005
    Concordville PA
    3,699
    Just like 3 years ago i drove a 88 International that had one of them. It was a black knob with a red button type of thing in the middle. Had a 350 Cummins Thats would never start below 30 unless you gave it a couple quick shot of eather. But it had a eather start on it. That was a mans truck.
  3. #23
    Root is offline Member
    Mar 2005
    At the wheel
    87
    My Co fleet used to be Mack CX613s... We were cautioned to idle'em, (set Cruise), @ 1000RPM.
    New trucks are all 9200i's w/C13s.. No word on upping the idle. :? But the Slobber Factor makes sense. Gonna bump mine up n see if anybody comes back at me on the sQualComm aboudit.
  4. #24
    yoopr is offline Board Icon
    Nov 2004
    12,865
    Quote Originally Posted by Mackman
    Yep-that was the Knob
    Surprised you didn't have a compression release Lever-those things were the Cat's meow when it got down around -20. Let the engine spin and slam down the lever and Poof-You've got Ignition :P
