Results 1 to 2 of 2
Thread: Semi Miss in engine or turbo
    stark21 is offline Rookie
    Dec 2005
    2
    Default Semi Miss in engine or turbo
    I have a 2006 Mack Vision today when I was driving home I noticed that the truck seemed to miss fire but goes away very quickly so it doesn't last long.. it idles fine with no sound of anything wrong.. I noticed there was some smoke out of the stack that was grey-blackish when getting up to speed.. not sure if it is a injector that is bad or if the turbo is starting to go.. engines sounds like it cuts out for a second when rpm below 1200.
  2. #2
    Doghouse is offline Senior Board Member
    Mar 2007
    1,010
    How many miles do you have, and has this been an issue before??
  3. This ad will disappear if you login
