+ Reply to Thread
Results 1 to 8 of 8
Thread: oil in glad hands
    KAIMIKAZEE is offline Member KAIMIKAZEE is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Sep 2005
    135
    Default oil in glad hands
    just recently i'd been getting some oil in my red glad hand.
    the oil looiks normal in color, not muddy or anything.
    i had the compressor (reman) replaced a year and a half ago and the dryer replaced during the winter...
    any reason why all of a sudden there is noticeably more oil showing up in the glad hand????
    any help would greatly be appreciated...
  2. #2
    Part Time Dweller's Avatar
    Part Time Dweller is offline Board Regular Part Time Dweller is on the right path.  You could probably safely loan them a quarter.
    Jan 2007
    Western Chicago Suburb, IL
    442
    The only way oil is getting in the air system is from the compressor.
    Sounds like it is time for a new one. Try to stick with a reputable company, like the OEM, to get rebuilt parts. There are lots of fly by night rebuilders that may charge less, but if it only lasts a year or so, how much did you save?
  3. #3
    no_worries is offline Senior Board Member no_worries is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Apr 2006
    1,106
    How long has it been since you replaced the dessicant for the air dryer?
  4. #4
    Kranky's Avatar
    Jun 2006
    Wisconsin
    1,108
    The dessicant in the air dryer takes out water, not oil.
    Actually, oil in the system will ruin the dessicant so it no longer is effective.
    I agree with PTD; the compressor is junk.
    As to the question about how long since he replaced the dessicant:
  5. #5
    Aug 2005
    jackassville (winnipeg, mb)
    3,181
    Yup compressor toast, have your valves started screwing up too? That will happen in short order.
  6. #6
    Jul 2007
    Savannah, GA
    9
    Quote Originally Posted by Part Time Dweller
    Another thing is if you get some off the wall reman vs. genuine compressor then if the compressor fails you can get your warranty anywhere in the nation, but if you have Jim-Bob's Compressor Rebuilders then you can only take it back to the place where you purchased it.
    Joseph @ Freightliner of Savannah Ga.
    Parts Sales
    912-964-8574 Ext:500
    I-95 Exit 109 behind the Enmark
  7. #7
    Oct 2006
    Nb
    794
    quote="Splitshifter"]The dessicant in the air dryer takes out water, not oil.
    many air dryers have a sump and a wire mesh screen for oil removal
    [/quote]
  8. #8
    Oct 2006
    Nb
    794
    Default Re: oil in glad hands
    Quote Originally Posted by KAIMIKAZEE
    maybe... it has just been collecting in the air tanks over the last few years ;0)
    if the oil is passing the air dryer, it means the dessicant is saturated, you need air dryer service
    before you service the dryer, you should verify that the compressor is not passing excessive amounts of oil.... as the other have already suggested, this is your most likely culprit. although... some oil passing is normal
    if the inlet of the air compressor is restricted, it will pass oil also
    don't forget that oil reaks havoc on all your valves, brake chambers, abs modulators, etc
  9. This ad will disappear if you login
+ Reply to Thread
