Every time the whether is above 85 degrees my temp light comes on whenever the temp gauge starts to climb towards the red(around 210degrees) and this trips the buzzer.This is when the truck sees some hill and maybe 4% grade at about 30k ibs load or more.I have a 1993 FLD and I am not ready for an inframe until 6 months down the road.The Odo. reads 1.2million miles.
For example the the gauge was climbing into the red on monteagle on I-24 and I had to pull on the side for the temp to go down.I also have the fan switch but it only kicks on above 1500 rpm.
The coolant level is normal.I did finally closed the faucets 2 days ago and that helped a bit but anytime above 85 degrees outside and I get this problem.
Can flushing the radiator help?This truck just hates hills but I can hit 75 on the flats.Do I need to test the coolant mixture?
Any ideas?
As for your fan, if you have a switch and change it to manual it should run all the time, not just above 1500 rpm. 8) 8)
