I'm a firm believer in synthetic oils, I use them regularly in all of our transmissions and differentials. they tend to withstand heat better and exhibit less viscosity breakdown. You can also go for longer periods between change intervals.
I'm just curious what everyone's thoughts are on using synthetics in the engines. I find it hard to justify that sort of expense, because engine oils are typically changed every 10,000 to 20,000 miles (depending on your fleet standards and truck application) Granted, you can get an extended enterval with the synthetic, but only an extra 10,000 miles maybe.
Do any of you think its worth the extra cost?
Sintetics is a MUST, for tranny and axles. But not worth an effort on engine. I know, some large fleets using it, with 60,000 oil change interval, but than again, i wouldn't recomend those trucks.
