+ Reply to Thread
Results 1 to 10 of 10
Thread: Super Ten Top Two Auto
    Collard Greens's Avatar
    Collard Greens is offline Board Regular Collard Greens is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Jul 2006
    Jacksonville, FL
    200
    Default Super Ten Top Two Auto
    I once knew how to stop the auot shift of the top two gears of a super 10. Does anyone remember how to do it? I forgot you know I have CRS alot.
    May God bless all in their ventures......Been gone while but now I'm back. Going to keep on trucking even though the freight is sucking.
    http://www.trukz.com
  2. #2
    Scoe's Avatar
    Scoe is offline Administrator Senior Board Member Scoe is a trusted source of information and would probably pick up your dry cleaning. Scoe is a trusted source of information and would probably pick up your dry cleaning.
    Jun 2003
    Portland, OR
    1,823
    It's been a while but if I remember correctly, when you are in 9th and the super ten tries to auto shift into 10th push in the clutch and the tranny will surge for a few seconds and when it's done let the clutch back out and you will be in manual mode to shift between 9th and 10th. I hope that this is correct.
    "In trucking, 2 wrongs don't make a right but 3 lefts do!!"
  3. #3
    Jul 2006
    Jacksonville, FL
    200
    Thanks Scoe. I will try it when I get back in the truck. I'm in office for a few weeks, my fiancee is expecting any day.
  4. #4
    Garmann is offline Rookie Garmann is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Sep 2006
    18
    Quote Originally Posted by Collard Greens
    When you figure it out post the answer. I would like to know this also.
  5. #5
    Sep 2006
    18
    Quote Originally Posted by Scoe
    This didn't work for me I was probably not timing it right.I will try again. I was just curious if you did get it to go into manual mode the way you describe. How do you get it back into auto mode?
  6. #6
    Fredog is online now Senior Board Member Fredog is a trusted source of information and would probably pick up your dry cleaning. Fredog is a trusted source of information and would probably pick up your dry cleaning.
    Apr 2005
    North Georgia
    3,665
    Quote Originally Posted by Garmann
    our mechanic unplugged mine, I will ask him on monday where the plug is and I will post it as soon as I can.
  7. #7
    Scoe's Avatar
    Jun 2003
    Portland, OR
    1,823
    The next time you shut off the engine it will default to automatic mode.
  8. #8
    Jul 2006
    Jacksonville, FL
    200
    Got R done. When it gets ready to go to 10th gear push in clutch put in neutral let it surge until you can rev up motor then go back in 9th split to high side and you should be able to shift last two manualy. But like it was said once you turn off engine it will go back to auto.
  9. #9
    Sep 2006
    18
    Collard Greens,Fredog & Scoe,
    Thanks for posting. I always thought there was a way to do this. The dealer my truck came from wasn't real helpful. When I get my truck back in few days I will try for manual mode again. It would be nice to be able to lock out the auto at times.
    Fredog. I don't want to disable it all the time. I would just like the option. I got into several miles of road construction at the right speed to where the truck was shifting back and forth. This is one case where it would be nice to lock out the auto shift.
  10. #10
    Apr 2005
    North Georgia
    3,665
    the only thing he told me was unplug it from the transmission which disables it all the time, I like it that way, but if you dont, maybe someone else can help you
  11. This ad will disappear if you login
+ Reply to Thread
